poping in front end after camburg spindle lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by checker c5, Mar 22, 2012.
  1. Mar 22, 2012 at 9:00 AM
    checker c5
    checker c5 [OP] DESERT RACER
    Trevor
    So Cal
    06 Trd offroad
    X runner valance, camburg spindles, 5100 bilsteins, defiant light bar, hella 700's
    i put the lift on last summer and im just recently experiencing a pop in the front end. any suggestions or has this happened to anyone else?
  2. Mar 22, 2012 at 9:12 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Retorque everything maybe some thing is loose
  3. Mar 22, 2012 at 9:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^
  4. Mar 22, 2012 at 9:16 AM
    yamaha73
    yamaha73 Well-Known Member
    Royce
    Madera ranchos
    1997 4runner, 1980 Toyota pickup
    4Runner- wagoneer Dana 44 front lunchbox locker. Rear stock axle spooled. Beadlocks and 36s 3link rear, leaf front, dual transfer cases 1980 pickup- exo cage. Locked front and rear on 40s dual transfer cases. Custom paint job
    Idk how the camburg is but most of.us who got maxtrac spindle have the pop and its the mount for our brake lines
  5. Mar 22, 2012 at 9:18 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Already retorqued everything here and its still happening! From those I talked to around 10 of us have popping in the front end with spindle lifts... I am still trying to figure it out...
    I havent seen my brake line mount rubbing at all. :confused:
  6. Mar 22, 2012 at 9:24 AM
    BAMFTACO
    Juan
    Kings bruh
    Mount a go pro in the front to see your suspension cycle and maybe locate the problem
  7. Mar 22, 2012 at 10:52 AM
    Blaise22
    Blaise22 Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
    I torqued the four bolts that connect the spindle to the lca to 110ft/lb and the popping went away. I have the camburg spindles as well.
  8. Mar 22, 2012 at 10:57 AM
    BAMFTACO
    Juan
    Kings bruh
    Op Retorque to factory specs to go over the recommended amount your upper and lowers basically everything in te front suspension
  9. Mar 22, 2012 at 11:06 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i have the pop also, i feel it in the steering wheel
  10. Mar 22, 2012 at 11:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is exactly what I have encountered with these spindles. You need to torque them right at 110#.
  11. Mar 22, 2012 at 11:26 AM
    anthony250f
    Anthony
    San Diego, CA
    i rhought it was related to steering, i feel it when im turning, it feels like the tie rod end is shifting.
  12. Mar 22, 2012 at 11:51 AM
    nfs257
    DFW
    She gone
    x2
  13. Mar 22, 2012 at 11:58 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Check your tie rod ends!
  14. Mar 22, 2012 at 12:47 PM
    anthony250f
    Anthony
    San Diego, CA
    i did, they are nice and tight, next step is to check the hub bolts and the lca bolts....even though i know they are tight...
  15. Mar 23, 2012 at 8:30 AM
    checker c5
    Trevor
    So Cal
    06 Trd offroad
    ya i didnt have it at first but recently i had it probably within the last 3-4 months. ill try some of these hopefully it works thanks guys
  16. Apr 14, 2012 at 8:07 PM
    anthony250f
    Anthony
    San Diego, CA
    solutions? its pissing me off...
  17. Apr 14, 2012 at 8:10 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ^ have you tightened them down?
    i got nothing after installing the new stuff, had it before so I am guessing the torques were wrong
  18. Apr 14, 2012 at 8:11 PM
    anthony250f
    Anthony
    San Diego, CA
    i checked the hub bolts, tight, lca bolts, tight as fuck! uca, tight, tie rods- leaking some grease but tight
  19. Apr 14, 2012 at 8:13 PM
    08pretaco
    az
    have you checked for play in your steering?
    inner,outer tie rods in good shape? is the rack tight to the frame?
  20. Apr 14, 2012 at 8:17 PM
    anthony250f
    Anthony
    San Diego, CA
    how do i check for play? i have shacked them and they dont move......its like im turning then turn a little more and POP...
