poping in front end after camburg spindle lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by checker c5, Mar 22, 2012.
  1. Apr 14, 2012 at 8:19 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    get the wheel off the ground and put one hand at 90 and the other at 270, opposing movements pull/push the outsides of the wheel. thats the easiest way. you could also get under the truck and check the racks mount points to make sure the bolts are tight
    also to add, are your factory LCA bushings in good shape?
  2. Apr 14, 2012 at 8:25 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    i also have this popping in my front end after installing my camburg spindles, i read somewhere on this site that it has something to do with the fact that the tie rods are flipped when attached to the new spindle. but im in no position to confirm or deny this.
  3. Apr 14, 2012 at 8:29 PM
    08pretaco
    az
    you know why they do the flip?
    iirc it is to prevent binding on droop
  4. Apr 14, 2012 at 8:55 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i would assume my bushing are okay, i will check all of this tommaro, my lower bj is leaking some grease to /:
  5. Apr 14, 2012 at 9:05 PM
    08pretaco
    az
    I just replaced everything suspension component wise and the pop is gone so definetly take a look into all those things as well as the lca bushings! idk how to check if those are good or bad other than unbolting them
  6. Apr 14, 2012 at 9:13 PM
    anthony250f
    Anthony
    San Diego, CA
    can you describe to me how your pop felt and when it occured? im going to do tie rods first
  7. Apr 14, 2012 at 9:21 PM
    08pretaco
    az
  8. Apr 14, 2012 at 9:27 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    I am looking into a spindle lift but I am a huge noise freak and hate hearing sounds from my truck. When is this popping happening most I am just curious??
  9. Apr 14, 2012 at 9:31 PM
    08pretaco
    az
    when turning the steering wheel at low speeds, at least for myself.
    I got over it and turned the volume up in the truck
  10. Apr 14, 2012 at 10:12 PM
    anthony250f
    Anthony
    San Diego, CA
    same here, for me its more of a feeling than a noise
  11. Apr 14, 2012 at 10:13 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Mines just a noise, I don't mind it, but when it happens while I'm trying to park somewhere everybody looks at me funny, haha
  12. Apr 14, 2012 at 10:17 PM
    08pretaco
    az
    At least you didn't make a loud ass noise grinding the hell into your cab mount and pinch weld parking and backing up. It was so so aweful lol
  13. Apr 14, 2012 at 10:21 PM
    anthony250f
    Anthony
    San Diego, CA
  14. Apr 14, 2012 at 10:42 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Haha, that's funny. I actually did all my trimming before i got my tires so that wouldn't happen.
  15. Apr 15, 2012 at 8:42 AM
    #35
    08pretaco
    az
    I trimmed and did the cab mount, but I have 315's on. Looks like you at 285
  16. Apr 15, 2012 at 8:44 AM
    #36
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Yeah I'm at 285s. How much clearance do you have with 315s? Are you clearing them with glass?
  17. Apr 15, 2012 at 8:49 AM
    #37
    08pretaco
    az
    Ya I have glass. Just installed my Burg LT and when turning now I barely scrap the pinch weld so ill either have to self clearance it or take a hammer to it. Now I am nowhere near my cab mount, at least that I have been able to tell
    I did the cab mount but was still rubbing it dead smack center of the frame
  18. Apr 15, 2012 at 8:59 AM
    #38
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    I'd just take a BFH to the pinch weld and flatten it down against the rest of the wheel well, that's what I'm going to do when I get new tires.
  19. Apr 15, 2012 at 9:00 AM
    #39
    anthony250f
    Anthony
    San Diego, CA
    where is the pinch weld?
  20. Apr 15, 2012 at 9:03 AM
    #40
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Backside of the wheel well on the firewall, it's underneath the stock black plastic inner liner
