Popped a head gasket.
Discussion in '1st Gen. Tacomas (1995-2004)' started by MrRiverMan, Oct 20, 2015.
  1. Oct 20, 2015 at 4:43 PM
    MrRiverMan
    MrRiverMan [OP] Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Bought a '96 3.4 with 140k a couple of months back and haven't driven it too much.
    Yesterday it started drinking coolant - drank enough that the temp gauge started climbing like mad, and I pulled over (before the temp gauge got to the red, but barely). Cooled it off and limped it a couple of miles to a friend's shop.
    Did the test - cooling system tested positive for combustion gases. Filled it with coolant (about a gallon) and drove home. The lid popped off the coolant reservoir on the way home, and I was down another 3/4 gallon.
    So now I'm looking at doing the head gaskets on this thing, and I'm wondering a couple of things.
    First, what all parts do I need? I assume I need head gaskets, intake mani gaskets, exhaust mani gaskets, probably a throttle body gasket - what else am I not thinking of? Timing belt has recently been changed, so I'm not gonna do a new one of those.
    Second, does anybody have any advice specific to doing this job on a 3.4? Things to look out for?
  2. Oct 20, 2015 at 5:39 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    a head gasket set contains all the necessary gaskets to rebuild all the heads a vehicle has. rock auto recommends buying some head bolts as well.
    just keep in mind it is a lot of work to tear down a 3.4 liter to get to a head.
    tear down intake, exhaust, ignition, fuel injection, power steering pump, AC compressor, 3 belts, fan clutch and fan (don't forget to protect the radiator, you have to pull the crank pulley off and it's easy to smack the radiator when doing this), 2 front timing covers, timing belt, cam shaft pulleys, valve covers, then remember how to put it all back together.
    you may also want to get the head pressure and vacuum tested to make sure the valves are still good. and also maybe resurface the head or just have it rebuilt.
    get a service manual. good luck!
  3. Oct 20, 2015 at 5:43 PM
    MrRiverMan
    WNC
    Yeah, I've pulled heads before, just not on this motor. I'm pretty comfortable that I can do the job, just wondering if folks had any specific tips.
  4. Oct 20, 2015 at 5:49 PM
    CodeSeven
    Serge.
    Coachella Valley
    Guess the only tips i have is that you have to remove the PS pump cause it's bracket is connected to the fan pulley mounting bracket. and you may not have to do the AC compressor cause I think that's just in the way of getting to a bolt for the hydraulic tensioner.
  5. Oct 20, 2015 at 5:55 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    I recommend removing the radiator, of course you can do with out it but you get more space and not a hole in your radiator. one other thing is check to see if the coolant cross over is seeping, if it is you will know use fipg to reseal it.
  6. Oct 20, 2015 at 6:14 PM
    MrRiverMan
    WNC
    I'm replacing the compressor anyway because I sheared the head off a bolt trying to swap a leaky AC line. I have the part from my parts truck, so no big deal. System is already empty from the leak, too.
    Thanks for heads-up on the PS pump.
  7. Oct 20, 2015 at 6:20 PM
    MrRiverMan
    WNC
    Thanks - I'll definitely be careful of the radiator. Truck is actually a T100, so there will be a little more room than on a Taco. I just post in here because it's the same motor as a Taco, and nobody really hangs on the T100 board (and my other truck is a '96 Taco, so this is where I've always been).
    If I bungle the radiator, I actually have a spare working one from my parts truck.
    I'll check the crossover, and good to know it doesn't need a gasket.
  8. Oct 21, 2015 at 12:35 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    A head may be warped or it could have a lot of corrosion. Head gaskets don't just blow for no reason, or so they say. Overheating with low coolant exposes the heads to higher temps compared to simply overheating because of a clogged radiator while maintaining full coolant for example. Just be prepared in case there's a problem with a head.
  9. Oct 21, 2015 at 3:54 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Second what he said. I would just add that you find a reputable machine shop, take the heads in to be straightened and surfaced. While youre in there, it would be worth paying extra and having a valve job done with new ferules and guides. Have the valves ground if necessary and refitted (should not need to).
    The farther you can tear it down, the cheaper it will be for the outsourced work. Ive had experience with snapping camshafts of BMW inline 6's, luckily its very difficult to do this on a 3 cylinder camshaft.
    I would just remove the radiator to avoid damaging it. Place a thick square of cardboard in the area the radiator would go to guard the A/C condenser from damage.
    Im curious to what your approach will be to the rear crossover exhaust pipe. From what ive read some people do, they will have a second person assist them, and lift up both heads with the crossover connected, rather then trying to unbolt it while in the engine bay. I haven't done this before on the 3.4L, so i cant say which way is better.
    And ONLY ONLY ONLY use OEM parts!! No Chinese ebay shit.
    ^ Most important part.
  10. Oct 21, 2015 at 8:22 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Get new head bolts. They are one-use-only torque to yield (?) bolts.
    For the head gasket itself, use OEM if you want it to last.
  11. Oct 21, 2015 at 1:25 PM
    MrRiverMan
    WNC
    New head bolts: yes, sounds like the best plan.
    OEM parts: yes, which is why I am making a list rather than buying an aftermarket kit.
    Rear crossover pipe: I'm gonna pull it off and put new gaskets in anyway. It doesn't look that bad to get to on the T100. There's lots more room under the hood than on a Taco.
    Remembering how to put it back together: yeah, that's the best way to do it. No bolts left over!
  12. Dec 6, 2015 at 5:44 AM
    MrRiverMan
    WNC
    So I finally got deep into this on Friday. Someone had obviously been in there before, a long time ago - I suspect a Toyota tech did the original recall replacement of the head gaskets under the warranty. Whoever it was did a pretty sloppy job.
    On the passenger side, the exhaust bearing caps were on the intake camshaft and the intake ones on the exhaust.
    Two of the head bolts were so loose that they turned with no resistance - not even finger tight. I think this explains the exhaust gases in the cooling system. Still not sure where all of my coolant was going - maybe I will learn more when I pull the other head.
    I'm going to pull the driver side head tomorrow and take them both to a machine shop. Wish me luck that the heads and valves are all still ok.
  13. Dec 6, 2015 at 5:49 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    You will notice a nice change after that machining :) she should be a little quieter as well. just did one on a cummins 5.9 and the noise difference after was incredible! Good luck!
  14. Dec 6, 2015 at 5:55 AM
    MrRiverMan
    WNC
    there were a couple of exhaust manifold studs loose as well, and bad gaskets at almost every exhaust junction. The truck has been so loud it was unbelievable. I think just sewing up all of the exhaust leaks is going to make a big difference.
  15. Dec 6, 2015 at 6:00 AM
    Clearwater Bill
    Billy
    Largo Florida
  16. Dec 6, 2015 at 7:36 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Let me tell you a little trick. Put the bolts back where they were after you take the part off or put them in the removed parts bolt holes and you will lessen the chance of having left over bolts. I have seen too many people just randomly throw bolt, screws, nuts in to a bucket. Doing that will make a 4hr job into a 8hr job.
  17. Dec 6, 2015 at 11:31 AM
    CodeSeven
    Serge.
    Coachella Valley
    Sounds good, dude. let us know the end result
  18. Dec 6, 2015 at 3:01 PM
    Caligula
    Los Angeles, CA
    Thats a good habit to have. I usually use a buck of small ziploc bags. Ever section i work on ill put i a separate bag, then simply mark it 1, 2, 3, etc as i progress, then count backward when reassembling. It works well when taking apart interior and body panels.
  19. Dec 6, 2015 at 4:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    Another disassembly/reassembly 'trick' that we didn't have easily way back when is pictures.
    Take the time to actually use a cell phone camera for something useful. Like what it looks like as you take it apart.
  20. Dec 7, 2015 at 4:54 AM
    MrRiverMan
    WNC
    Yeah guys, I take pics before I take something apart, then put the bolts in labeled ziplock bags. So hopefully it will all go back together smoothly.
