Popped a head gasket.
Discussion in '1st Gen. Tacomas (1995-2004)' started by MrRiverMan, Oct 20, 2015.
  1. Dec 7, 2015 at 2:33 PM
    MrRiverMan
    MrRiverMan [OP] Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Got the other head off today, and all the valves actually looked good. Took it to a machine shop that I had heard good things about - price seems very reasonable for cleaning/pressure testing/decking, and also not terribly bad if I need a valve job.
    My phone takes crappy photos, but here's what I've got.
  2. Dec 7, 2015 at 3:15 PM
    Clucky
    Clucky Well-Known Member
    W
    WC to EC back to WC
    00 SR5 Stock 5 Speed
    & 12 TRD Stock 6 Speed
    Did you drain the coolant from the block? I'm guessing no. What is that green thing in cylinder 2?
  3. Dec 8, 2015 at 4:33 AM
    MrRiverMan
    WNC
    I drained it, but there was still a little in the head when I pulled it.
  4. Dec 8, 2015 at 6:09 PM
    MrRiverMan
    WNC
    woohoo! Heads came back from the machine shop today - no cracks, no leaks, no valve work needed! They're cleaned and decked and ready to go on next week. Waiting for the water pump to come in, then it's game on for putting it all back together.
  5. Dec 8, 2015 at 6:37 PM
    Clucky
    W
    WC to EC back to WC
    Nice job. Any problems getting the crank bolt or cam sprockets off?
  6. Dec 8, 2015 at 6:41 PM
    MrRiverMan
    WNC
    Cams came off with a breaker bar. Crank bolt zipped right off with an impact gun. The crank pulley was a little tricky - had to put the bolt back in to rest the puller against it.
    I'm going to pull the next ring of the crank off before reassembly to replace the front crank seal, which is leaky. Wish me luck.
  7. Dec 8, 2015 at 7:07 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    good luck. won't need it though :thumbsup:. the hard part is taken care of. just make sure you follow the appropriate processes to put it all back together. have a haynes manual? get one if not. it will have all the torque specs on it.
  8. Dec 10, 2015 at 3:31 PM
    MrRiverMan
    WNC
    I'm using the FSM, not the Haynes. Water pump came in today. A few more parts coming Saturday, then it's game-on next week.
