Popped off mud flap, stripped screw hole
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandyman, Mar 11, 2016.
  1. Mar 11, 2016 at 8:27 PM
    Sandyman
    Sandyman [OP] Well-Known Member
    Sandy
    Los Anchorage
    '12 DC Sport Limo
    Just me
    I backed into a snowbank and the front mudflap popped off. Well I actually like mud flaps and went to remount then. I found that the 3 screw holes are stripped to where they will barely hold the screw. (btw, new plastic "rivets")
    What have you done to repair the screw holes? If it were wood I would stick in a chopstick and break off the excess but this doesn't work so well in plastic.
    Thanks
  2. Mar 11, 2016 at 8:34 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Get a bigger screw, it's just plastic that they are screwed into from what I remember. Both my tacomas had them removed the first day
  3. Mar 11, 2016 at 9:08 PM
    Pigpen
    Dan
    Northwest Montana
    I did the same several times and bought cheap aftermarket mudflaps. Now the screws stay put and the flap tears. Then I put on a new one. If I'm going wheeling, I take the 5 minutes to remove them first.
  4. Mar 11, 2016 at 9:14 PM
    Sandyman
    Sandy
    Los Anchorage
    '12 DC Sport Limo
    Just me
    Bigger screw it is!
    (Duh, now why didn't think of that?)
