Popping Dent on a Rear Bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpeedBlueTaco0502, Apr 2, 2012.
  1. Apr 2, 2012 at 4:28 PM
    SpeedBlueTaco0502
    SpeedBlueTaco0502 [OP] Well-Known Member
    Nick
    Fresno CA
    TRD Pre Runner
    Hankook Dynapro ATM RF10, Plasti Dip Inner Grille, Plasti Dip lower bumper. Bilstein 5100 1.75
    I have a small dent, anyone have a secret to pop a ding on my chrome bumper?
  2. Apr 2, 2012 at 4:31 PM
    Aw9d
    Aw9d That one guy
    Take it off and hit it from the other side with a rubber mallet maybe? Not sure if dents remove out of the bumpers very well if at all.
  3. Apr 2, 2012 at 4:32 PM
    SpeedBlueTaco0502
    Nick
    Fresno CA
    TRD Pre Runner
    I'll give it a try...I'm looking at ehow on this too.
  4. Apr 2, 2012 at 4:57 PM
    SpeedBlueTaco0502
    Nick
    Fresno CA
    TRD Pre Runner
    That's what it looks like right now....
  5. Apr 2, 2012 at 5:04 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I wonder if the upside down can of air would work on that?
  6. Apr 2, 2012 at 5:25 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    you can try use a heat gun heat it up good, than use the dust buster to spray on it, since it is cold air, metal will pop back out.
    I do use this on my wife car door, it work.
    Hope this can help.
  7. Apr 2, 2012 at 6:52 PM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    It's only a few dollars to try.
    To the op, there are tons of videos on it if you're not familiar with it. Just Google "dust dent fix" and you'll get shotloads of vids. There are some on here, but hundreds on youtube. It would just be faster.
  8. Apr 2, 2012 at 6:55 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    not gonna work...... the compressed air trick may work sometimes on sheet metal dents on your body panels, but the steel in the rear bumper is much thicker. doubt a rubber malet will even take that out. try a 4lb sledge and a block of wood.
  9. Apr 2, 2012 at 7:01 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
  10. Apr 2, 2012 at 7:31 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    here is a question. How often do people ask you what happened to your truck and point at the dent?
  11. Apr 2, 2012 at 7:34 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    huh?
  12. Apr 2, 2012 at 7:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    This.
    That's on a heavy bumper, it's chrome, and it's on or near the corner.
    Compound curves don't generally "pop" are are hard to work with a hammer and dolly.
  13. Apr 2, 2012 at 7:52 PM
    tweeek
    tweeek Well-Known Member
    Victoria, BC
    2006 Tacoma Access Cab TRD OR
    I had a similar dent (But bigger). I pounded it out with a hammer & wood but it will never look perfect. I pounded it out close, then sanded, bondo'd, sanded some more and repainted the bumper with 5 or 6 coats of spray on bedliner. It came out amazing and looks way better than the chrome ever did.
    You would have no idea there was ever a dent there, even on close inspection.
