POPPING FUSES
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dougtara, Jan 3, 2014.
  1. Jan 3, 2014 at 5:47 AM
    dougtara
    dougtara [OP] Well-Known Member
    Doug
    Fayetteville, NC
    '09 Prerunner DCSB
    borla headers and exhaust 2" lift icon rear shocks bilsten 5100 coilovers specter cold air intake falken rocky mtn 285 satoshi grill land cruiser badged HID 4" BAMF antenna mount with 4' firestick
    I need some help? I just put a Cobra 19 cb and NOAA in my taco. very simple setup that pulls its power from the 12V cigarette lighter. Followed the directions to a T since I am not very good with electrical. Every time I turn on the radio it blows the fuses. There are 3 fuses in the setup including the accessory fuse in the truck. Both of the inline fuses in the radio power cord are 250V.
    Like I said, I am not that good with electrical so any advice would be super helpful....
  2. Jan 3, 2014 at 5:48 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Go back and double check everything.
  3. Jan 3, 2014 at 5:53 AM
    dougtara
    Doug
    Fayetteville, NC
    '09 Prerunner DCSB
    that is the plan for today... was getting frustrated with it and had to walk away..
  4. Jan 3, 2014 at 5:56 AM
    BostonBilly
    Easton
    Ya but you will feel better when you find it.
  5. Jan 3, 2014 at 5:58 AM
    dougtara
    Doug
    Fayetteville, NC
    '09 Prerunner DCSB
    so true... im hoping it was just bad fuses and the taco gods will smile on me
  6. Jan 3, 2014 at 6:01 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    I'm not an expert on this, but I'm guessing your radio(s) are pulling more amps than what your fuses allow. You need to look up how many amps the radios pull (combined if you're powering both off the cig lighter power). Then put fuses in that allow that amount of amps. Might want to research if there's a limit on the allowable circuit amperage for the cig lighter circuit too. :notsure: but that's my best guess.
  7. Jan 3, 2014 at 6:02 AM
    dougtara
    Doug
    Fayetteville, NC
    '09 Prerunner DCSB
    thanks... didnt think about that
  8. Jan 3, 2014 at 9:28 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    If MQQSE's comment doesn't work, I think it will, double check any grounds that you put in and make sure they are tight.
  9. Jan 3, 2014 at 10:29 AM
    dougtara
    Doug
    Fayetteville, NC
    '09 Prerunner DCSB
    It was the amps... I did some research and my fuses were too low... Put in the corre t fuse and pop went the CB... Looks like im calling cobra this afternoon... Thanks for the help guys
  10. Jan 4, 2014 at 6:37 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    DO NOT JUST PUT LARGER AMP FUSES IN YOUR FUSEBOX !!!!! This is how wire fires start in vehicles. If you keep blowing fuses running it through the power outlet in the dash then either your radio is shorted or you are drawing too much power. If you take out a 10 amp fuse and put in a 20 amp fuse then the fuse is no longer the weakest link in the circuit, your wiring is. Run a 14 gauge wire directly to the battery with a 20 amp fuse as close to the battery as possible. The only problem with this setup is you have to remember to shut it off when you shut your truck off.
  11. Jan 4, 2014 at 6:48 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    +1 Truth
  12. Jan 5, 2014 at 7:14 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    With the inline fuses removed, recheck your wiring with a voltmeter. If wiring is good, and check the radios for a power lead short to ground.
