Popping fuses
Discussion in 'Technical Chat' started by cole47, Sep 26, 2009.
  1. Sep 26, 2009 at 1:17 PM
    cole47
    cole47 [OP] Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    my truck keeps popping the AUX 15 amp fuse (radio,clock, and outlets) what could be causing this?
  2. Sep 26, 2009 at 2:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im thinking something is shorting out?
  3. Sep 26, 2009 at 2:20 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Ya gotta fess up to any and all mods you've done to the truck especially with that circuit. Vague questions will get you vague answers.
  4. Sep 26, 2009 at 7:13 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    all thats done in the wiring aspect is a subs and amp and aftermarket headunit (professionally installed) and my fogs which is about impossible to screw up...i thought i may have been my GPS in the outlet because i unplugged it and everything stayed working for about 2 or 3 minutes opposed to the second i flip the switch, but now nothing is plugged up, ive taken the fuse out of the amp power wire, and the fog light fuses are out and its still blowing them.....
  5. Sep 26, 2009 at 7:20 PM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    Ok, you've eliminated the amp & fog lights. Something else on that circuit is still doing it. Even though something may have been professionally installed, doesn't mean they don't make mistakes. Also, a wire could be pinched and eventually made contact with ground. Good luck.
  6. Sep 26, 2009 at 7:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ugh....chasing wires is a beeotch. good luck man.................sounds like a dead short.
  7. Sep 26, 2009 at 7:24 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    thanks for the help fellas....no radio sucks balls....:lalala:
  8. Sep 27, 2009 at 11:35 AM
    jinxed77
    jinxed77 Well-Known Member
    06 4.0L TRD SR5 4x4
    Does it blow instantly? Most likely it's the radio incorrectly installed. It happens all the time. Professional install or not. If it were me I would go disconnect all aftermarket accessories completely. One at a time reconnect when it blows the fuse you know which one it is. Thats about all you can do at home without the professional equipment. Go remove the radio unplug the main connector at the radio and see if it still blows. You don't have a body lift do you? Make sure you do not have any access. plugged into the cigarette lighter. Another thing look inside your power port and cigarette lighter makse sure their is nothing metal stuck in their and make sure the contacts are not touching the body of the plug.
    NO MATTER WHAT DO NOT PUT A BIGGER FUSE IN!!!!DO NOT JUMP THE FUSE IN ANY WAY!!!DOING SO MAY RESULT IN A MELTED WIRING HARNESS!!!
  9. Sep 27, 2009 at 1:14 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    ive had that radio in for like 2 years and thats the only aftermarket thing hooked up...
  10. Sep 27, 2009 at 1:34 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    found the problem....a broken end tip off a phone charger was stuck in the cigarette outlet....thanks for the help guys
  11. Sep 27, 2009 at 4:25 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    Ha Ha ,glad you found it. I've ran across pennies and earrings and all kinds of stuff in cigarette lighters.
  12. Sep 28, 2009 at 10:54 AM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    thanks for your help man
  13. Sep 28, 2009 at 11:18 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    :rockband::rockband::rockband:
    Crank it up!!
  14. Sep 28, 2009 at 1:18 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    :headbang:
