Popping in front suspension! Help!!
Discussion in 'Suspension' started by Tylerpeterson, Aug 15, 2018.
  1. Aug 15, 2018 at 3:13 AM
    Tylerpeterson
    Tylerpeterson [OP] Member
    Recently I started feeling excessive play in my steering wheel as well as clunking and popping while I drive at lower speeds. At speeds of 70mph+ I have a bad vibration throughout the truck. I am trying to figure out what’s going on because it’s driving me nuts!! I had the tires balanced, which did NOT take away the vibration. I replaced my inner tie rods as well as my tie rod ends. I also replaced my front and rear shocks. I was told that it might be lower control arm bushings so I took it to Toyota and they told me that my bushings are fine and it looks like everything is tight. After having them perform an alignment for me, 2 weeks later I was out of alignment. My U-joints and ball joints seem to be nice and tight as well.. Please help!
    Here is a video I uploaded of the popping:
    https://youtu.be/fvfcArol_dk
    I appreciate any advice I can get!
    DriftingonaMemory810 likes this.
  2. Aug 15, 2018 at 11:59 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I had the same popping noises. It really is the LCA bushings. Even though the bushing look fine, they're worn out so they don't have the same rigidity. I replaced the LCA's with Moog aftermarket ones that have urethane bushings and the popping went away.
  3. Aug 15, 2018 at 3:24 PM
    Tylerpeterson
    Thank you! Did you replace the cam bolts as well or use the originals?
  4. Aug 15, 2018 at 10:44 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    I replaced them with Moog's version with a grease zero and that was a big mistake. They went out of round within months b/c of the cheap steal and loss alignment because of that.
    Luckily I saved my original cam bolts. Living in the CA desert, they hardly had any rust. I just coated the bolt with a good amount of anti seize and put them back in place of the Moog garbage cam bolt.
  5. Aug 15, 2018 at 11:05 PM
    Tylerpeterson
    I’m going to give it a try! Thanks for the info. Hopefully I can salvage my cam bolts.
  6. Aug 16, 2018 at 4:54 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    One thing to be ready for is solid poly bushings will transmit a LOT more energy into the truck. The original rubber bushings are actually quite good at taking care of a lot of little imperfections in the road and such. That first initial hit before the suspension starts doing its work you will now feel. I know this because I recently did my bushings. That being said, the noise I had is now gone and the truck holds a perfect alignment.
    Biscuits likes this.
  7. Aug 17, 2018 at 4:04 PM
    ItalynStylion
    Steven
    DFW, Tx.
    One other thing to mention is your cam bolts on the LCAs might be too loose. I just got my truck aligned this week and had a popping noise when turning or changing directions. It was on the right side exclusively. I got under the truck and checked the torque on the cam bolts. The left side was VERY tight. The right side wasn't torqued down AT ALL. Once I tightened it up we were good to go. The vibration you have might be related to the alignment being bad too.
    Biscuits and DrFunker like this.
  8. Aug 18, 2018 at 11:40 AM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I've been chasing a popping / clunking noise down in the front end for awhile and finally traced it down to a worn steering rack guide. I was also having excessive play in the steering wheel like you mentioned. It might be worth checking to see if thats the issue. You just have to pull the drivers side boot off the steering rack and have someone shake the steering wheel while you watch the shaft coming out of the rack. If the shaft has any up and down play then the steering rack guide needs to be replaced. It was a $50 part, a 20 min job, and made my steering feel like brand new.
  9. Aug 19, 2018 at 5:30 PM
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    2nd gen too? I’m having some sounds and every suspension bushing is new, new UCA, new LCA, new shocks and mounts, new hub assemblies.....
  10. Aug 19, 2018 at 7:04 PM
    austinmtb
    Austin
    Southern Oregon
    2nd gen tacomas should have steering rack guides as well
  11. Aug 27, 2018 at 12:55 AM
    Tylerpeterson
    So I replaced the driver side LCA with Moog's version. I didn't have time to get the other side done but it made a big difference! The popping went away and it feels better so far just with one side done! Thanks for the help! I'll be doing the other side soon.
  12. Aug 27, 2018 at 12:56 AM
    Tylerpeterson
    Thanks for the advice! I'm going to check that out as well!
  13. Aug 27, 2018 at 12:59 AM
    Tylerpeterson
    Thanks for the heads up! I can see what you mean, I can feel the springy feedback when I drive now. But the popping went away and it does feel better. I still have rubber bushings on the passenger side so I probably haven't felt the worst of it until the other side is done. Thanks for the help!
