Popping noise after lift install
Discussion in 'Technical Chat' started by H Bomb, Feb 25, 2012.
  1. Feb 25, 2012 at 1:25 PM
    H Bomb
    H Bomb [OP] Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    I have a 92 pickup. I just lifted it with a rough country drop bracket lift. When I have the steering wheel at full lock left, it makes a metal on metal popping noise as if something is binding. What could it be? We have replaced the tie rods and lower ball joint. The sway bar is removed, so those aren't the culprit. I can't see anything binding. However the whole lower ball joint/ control arm pops and vibrates when turned all the way. All the bolts are torqued to spec. Any ideas would be helpful. Thanks!
  2. Feb 25, 2012 at 3:29 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    On an IFS it could be a CV joint or a wheel bearing, on a solid axle, it could be a U joint or wheel bearing. If you need help diagnosing which one these are, post up some more info.
  3. Feb 25, 2012 at 3:36 PM
    H Bomb
    CV is a good idea. That would be an easy thing to try. I replaced the driver side one, but not the passenger side one. There isn't any movement when I move the wheel, so I don't think wheel bearing is it. I know I need a new idler arm, but every thing else seems to look fine...
  4. Feb 25, 2012 at 3:39 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    If you got the wheel bearing diagnosis you probabaly know how to daiagnose a bad CV.
  5. Feb 25, 2012 at 3:50 PM
    H Bomb
    The CV appears to be fine. Where the CV meets the diff, it is a bit loose...but I don't know if that is normal or not. Could lower control arm bushings cause the noise?
  6. Feb 25, 2012 at 3:53 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Maybe, are the bolts tight? Is there any play in the bushing? Also check that the strut rod nut is tight as well.
  7. Feb 25, 2012 at 3:56 PM
    H Bomb
    The bolts are tight. No play in the bushing area from what I can tell. I'm not certain what a strut nut is...but I don't think I have one...
  8. Feb 25, 2012 at 4:00 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A shock and spring combo is a strut. Not sure what your truck has, but I've heard popping noises that all it was, was a loose nut or bolt. Last one was a strut rod top nut.
  9. Feb 25, 2012 at 4:03 PM
    H Bomb
    I see. Yeah, no springs on the truck. It has a torsion bar suspension.
    Thanks for all the input by the way! I hope to figure it out soon...
