Popping noise coming out of 4wd into 2wd
Discussion in 'Technical Chat' started by RaleighTaco, Mar 6, 2014.
  1. Mar 6, 2014 at 4:58 PM
    RaleighTaco
    RaleighTaco [OP] Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    So today i switched in and out of 4wd due to driving in and out of a field. Swithcing into 4wd no problem but everytime i switched out into 2wd it made a loud popping noise?
    Anyone else have this issue? or is this a normal sound
  2. Mar 6, 2014 at 4:59 PM
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    I tried different methods to ie. at a full stop, wheels turned and straight, and at a slow roll forward and reverse
  3. Mar 6, 2014 at 5:00 PM
    Tacoma Mike
    Southern Maine
    Yeup... Under certain conditions
  4. Mar 6, 2014 at 5:01 PM
    Deidara7117
    Deidara7117 Active Member
    Brandon
    Houston Texas
    A Tacoma
    ICON 3 leaf progressive AAL with Bilstein 5100 shocks and OME 885X coils
    mine does the same..
  5. Mar 6, 2014 at 5:10 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yes loud noises are " normal " in many circumstances with our trucks along with sloppy CV's that you would consider broken on another truck :/ In all seriousness now that I said that I wonder if that noise is a " rebound " in that sloppy half shaft into the front diff ?
  6. Mar 8, 2014 at 6:56 PM
    YotaOwner
    YotaOwner Well-Known Member
    Zack
    North Carolina (MAFB KS)
    2013 Tacoma Accesscab SR5
    My owners manual literally says loud popping sounds and vibrations while in 4H are normal and shouldn't be a reason for concern.. I still think it's sketchy though
  7. Mar 8, 2014 at 7:02 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    On my first gen it always "pops" out of 4wd when i've been in 4wd, turned (slight bind in the driveline), stopped, then pressed the button to go into 2 hi
  8. Mar 8, 2014 at 7:04 PM
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Yeah I can understand a pop when you turn your wheel all the way in 4wd but not just coming out of it into 2
  9. Mar 8, 2014 at 7:04 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Try to let off the accelerator while it switches in or out of 4WD OP
  10. Mar 8, 2014 at 8:59 PM
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    I thought i posted everything that i tried. I tried at a full stop, wheels straight, wheels turned, in reverse, slow roll reverse and forward, in park, in nuetral lol Im not to worried about it but i dont think its a normal thing
  11. Mar 8, 2014 at 9:02 PM
    95 taco
    95 taco Battle Born
    Unless you only went straight or turned the exact same amount both ways (if you turned, or if the wheels left dead center) there will always be driveline bind with 1 exception, you're on a very slick surface that let's each wheel spin individually.
  12. Mar 9, 2014 at 6:04 AM
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    I can understand that
