Popping noise going over bumps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seachicken27, Dec 15, 2010.
  1. Dec 15, 2010 at 9:07 PM
    seachicken27
    seachicken27 [OP] Member
    Richmond VA
    10 TRD Sport
    Hey guys,
    So I'm new to TW, and have a question. I have about 2,300 miles on my 2010 DCLB Sport, and I have noticed that going over speed bumps or other rought terrain a popping noise has developed as soon as I start to go over the bump. It sounds like it is coming from the front passenger side wheel/suspension area. It makes the noise going over just about anything over 1 or 2 inches in height at just about any speed. I don't know much about suspension tech, so any thoughts? Should I go ahead and take it to the dealership so they can tell me everything is normal? Thanks.
  2. Dec 16, 2010 at 4:40 AM
    CCRT
    CCRT Member
    2008 Tacoma Access Cab 4X4 Indigo Ink
    Dose it make the noise if you apply slight brake pressure while going over these bumps?
  3. Dec 16, 2010 at 8:23 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    03 regular cab 4x4
    Probably just a bad sway bar link. But on a 2010 why not just bring it back to the dealer?
  4. Dec 16, 2010 at 9:14 AM
    seachicken27
    Richmond VA
    10 TRD Sport
    it makes the noise regardless of brake pressure. and I will take it to the dealer, but it's just such a hassle sometimes...
  5. Dec 16, 2010 at 9:18 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Is the speed bump steep enough that the front mud flap hits the speed bump?
  6. Dec 16, 2010 at 4:56 PM
    seachicken27
    Richmond VA
    10 TRD Sport
    no, the road i live on has a bunch of speed "humps" which are not as steep and are longer than speed "bumps." this is why it is bothering me because I have to travel over 11 of them when I leave my house everyday. Thus the noise is quite noticeable to me. It also seems the noise has developed with the drop in temps, but that may just be a coincidence.
