Popping noise has it hits bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomasport82, Nov 26, 2015.
  1. Nov 26, 2015 at 11:02 PM
    Tacomasport82
    Tacomasport82 [OP] New Member
    2014 Tacoma TRD Sport Prerunner
    Stock
    Okay I'm new on here but recently I have notice a popping noise coming from the right front of my truck , which is a Tacoma 2014 Trd sport 2wd. Well the noise sounds more like a loose plastic around the cab area on the floorboard as I felt it sitting in the passenger seat. Recently took it to the dealer and had the strut, link, bump stop replaced on the right side and it's still there ? I'm lost here. Everything is tighten, even the body mount bolts were nice and tight . But his happen more often when it's been sitting over night or on a cold morning, I have notice that as the day warms up it gets quieter but still there . It doesn't do it all the time , only when it wants to.any suggestion will be much appreciated , thanks
  2. Nov 27, 2015 at 10:07 AM
    Pigpen
    Dan
    Northwest Montana
    Get your LCA bushings greased, they may be starting to seize - it'll happen eventually (sooner than later) without attention. This may or may not be what you're hearing. If you do them one at a time you shouldn't need to re-align.
  3. Nov 27, 2015 at 10:09 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Hmmmmmmmmmmmmmmmmm how easy are they to get out?
  4. Nov 27, 2015 at 10:18 AM
    Pigpen
    Dan
    Northwest Montana
    Rumor has it they're not too tough. That said, I was using a punch and a BFH. Mine never budged. I tried using a jack to relieve pressure under the bolt, but nothing... All of this, of course, with the wheel off and truck properly supported. Mine are on until I cut them off, I think. My suspicions were reinforced on my last alignment, when my mechanic had trouble getting my numbers close to where I wanted them.
    My driver side makes an awful noise when it flexes. It's a combination creak/pop that's a little disturbing.
  5. Nov 27, 2015 at 10:20 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Do you have part numbers for new ones? And let me guess they all seem to seize because Toyota doesn't grease them?
  6. Nov 27, 2015 at 10:25 AM
    Pigpen
    Dan
    Northwest Montana
    Affirmative on the bold type.
    I didn't look for the part#, but my dealership wants around $200 per side - just for parts. This is the main reason I haven't done them. I know there's a MOOG kit - I've read mixed reviews about the quality and fit of the parts. There's a bushing kit from Energy suspension (I think) that's reasonably priced, but if I could get the bolts out I'd just grease the stock bushings.
  7. Nov 27, 2015 at 10:27 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Sounds like a nightmare.
