Popping noise under hard acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by southla, Jul 15, 2024.
  1. Jul 15, 2024 at 10:37 AM
    southla
    southla [OP] Member
    What’s going on guys. I’ve got a 2011 access cab 4.0 4x4 AT making a weird popping noise under load. It was for a time only happening while trying to downshift around 40mph or so, paired with low RPMs (when you get stuck in too high of a gear), but now when I punch the gas, its happening at a wider range of speeds. Fairly sure it’s coming from rear portion of truck. My first thought is the slip yoke, but it almost sounds like an exhaust backfire and it can occur in a quick succession of pops at times. Any initial thoughts?
  2. Jul 15, 2024 at 10:39 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Any CEL's? If it's popping then my first thought is MAF sensor cleaning or fouled o2 sensors. You'll want to get it figured out soon or your catalytic converters could be in jeopardy.
    cruxofthebisquit likes this.
  3. Jul 15, 2024 at 10:39 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Got a Video of it:popcorn:
    GilbertOz likes this.
  4. Jul 15, 2024 at 11:15 AM
    southla
    southla [OP] Member
    No CEL. Cleaned my MAF a couple weeks ago. I’ll try and get a video this afternoon on the way home.
    abou824 likes this.
  5. Jul 16, 2024 at 10:59 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my frame was popping under load
    it was rusted out bad near the cats
    deanosaurus likes this.
  6. Jul 16, 2024 at 1:29 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Not sure what year but perhaps mid exhaust pipe to cats there is a dual spring-loaded junction with a semi-hard donut. Internal muffler rusted out. Bed bolts in rear. Front radiator bushings (body mounts). Tensioner assembly worn out. Many driveline parts. Ball joints. Sway bar bushings or end links. Noise type and location are often hard to pin down. Good hunting!
  7. Jul 16, 2024 at 1:33 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    was it poping before cleaning the MAF? I'm always suspect of that thing when popping occurs if it's actually the engine and not loading of suspension.
  8. Jul 16, 2024 at 3:54 PM
    southla
    southla [OP] Member
    Welp, 2 days of trying and I can’t get it to occur. I’ll keep trying hah
    abou824 likes this.
  9. Aug 12, 2024 at 11:09 AM
    southla
    southla [OP] Member
    Finally got it to occur again. It seems to occur once the truck is warm (driving for more than 5 minutes or so), and it isn’t really tied to a specific gear. I originally thought it may be a torque converter issue but that seems to be a 4th to 5th issue.
    Can hear it best at about 13–14 seconds. Almost sounds like 3 pops like a loose driveshaft u joint or something, but those are all new and it occurred before I changed them also.
    Thoughts?
