Popping noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Babyseabass, Sep 25, 2019.
  1. Sep 25, 2019 at 4:11 PM
    Babyseabass
    Babyseabass [OP] Member
    Sebastian
    2019 Tacoma 4x2 stock sr5
    None
    I just got my Tacoma last Friday not even 300 miles in and I’m hearing a popping noise coming from the front right after car has sat for a minute off. Happens in the mornings and when I leave work. Don’t know if anyone else has this issue.
    No modifications whatsoever not even wheels yet
  2. Sep 25, 2019 at 4:42 PM
    Cementing
    Cementing Well-Known Member
    2019 Tacoma TRDOR Cement
    Probably hearing the ABS check
  3. Sep 25, 2019 at 4:46 PM
    tcjacado
    tcjacado Well-Known Member
    Are you applying the brakes at the time you hear the noise?
  4. Sep 25, 2019 at 5:25 PM
    Babyseabass
    Sebastian
    None
    No brakes are being applied. It does the abs check every time you start the car right ?
  5. Sep 25, 2019 at 5:28 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Auto trans? If so, it's probably the parking gear aligning. If you park on flat ground, sometimes the gear doesn't quite click in until the wheels roll ever so slightly. I've noticed that many times on my old car, and new Tacoma. Not a worry in the world about it.
  6. Sep 25, 2019 at 7:20 PM
    Babyseabass
    Sebastian
    None
    Greatly appreciated guys. First time truck owner and taco fan just want to make sure my baby run right
  7. Sep 26, 2019 at 8:26 PM
    Babyseabass
    Sebastian
    None
    Update. Noise is coming from rear after having the hand brake applied. And moving for about 10-20 feet noise is heard
  8. Sep 26, 2019 at 8:52 PM
    tcjacado
    Could be a issue with the rear brake shoes, there have been a few issues regarding them on earlier models.
