Popping noises in 4hi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Owenhall, Aug 18, 2024.
  1. Aug 18, 2024 at 9:50 PM
    Owenhall
    Owenhall [OP] Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    Recently my truck has developed an issue were it pops when turning in 4wd when turning sharply I was wondering if anyone may know what it is.
  2. Aug 18, 2024 at 9:56 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Cv axle would be my first guess. Have a friend help you pin point which corner of your truck is making the noise.
    TnShooter likes this.
  3. Aug 19, 2024 at 4:42 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You're not supposed to turn sharply when in 4X4. Even off-road unless you're on extremely slick roads like ice covered roads. I suspect you do have a CV axle or 2 that are bad. Operating in 4X4 where traction is good and turning corners will cause that.
  4. Aug 19, 2024 at 8:46 AM
    Owenhall
    Owen
    Lift 33s
    I was turning in sand I replaced the drivers side cv axle. I haven’t had this issue when turning in 4wd before do you think the new cv axle is bad already. It’s appears to be popping on drivers Side!
  5. Aug 19, 2024 at 8:47 AM
    Owenhall
    Owen
    Lift 33s
    It also popped when accelerating in a straight line in sand.
