Popping sound when flexing over roots
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cgrhyne, Sep 11, 2012.
  1. Sep 11, 2012 at 11:45 AM
    cgrhyne
    cgrhyne [OP] Well-Known Member
    Cameron
    Lincolnton, NC
    2002 4Runner (the best 3rd gen)
    Bilstein/OME Lift, 5th Gen Wheels, BFGs, fun stuff... Had a 3rd Gen, twin turbo'ed it (traded in on a F150 Gen 2 3.5 Ecoboost)
    I have a spot I hunt that requires my taco to cross some roots and flex a little bit. Nothing real bad (6-12 inchs is the drops) and nothing that requires hard turns, but there is a popping/stretching sound that seems to come from the front springs. I do have the stock springs with the 5100's set at 2.5 and the rear has progressive aal. No diff drop or anything.
    Ive been through this bottom with several other vehicles without any issues, but this popping noise has me a little worried because it does it every time i go through the spot.
    Anybody else having these issues?
  2. Sep 11, 2012 at 11:47 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Maybe try lookin at the sway bar links to make sure they are tight. I'm not real sure
  3. Sep 11, 2012 at 11:49 AM
    cgrhyne
    Cameron
    Lincolnton, NC
    should also note... truck only has 2500 miles (only flexed about 6 times total)
  4. Sep 11, 2012 at 11:49 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sway bar contacting the coils ?
  5. Sep 11, 2012 at 11:50 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    I'd also say check your sway bar to make sure it's tightened all the way down. If not that then maybe you already have some bad bushings in your LCA's. From here, may have to get some more people in here.
  6. Sep 11, 2012 at 11:58 AM
    cgrhyne
    Cameron
    Lincolnton, NC
    I dont think it is the sway bar contacting the coils, but I will check. It doesn't do it any other time unless its a decent flex amount. Cant get it to make the sound under normal driving conditions, but it does it every time when I go through this certain area on my way to the stand.
  7. Sep 11, 2012 at 12:35 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    All this reminds me of the old joke where the guy goes to the doctor to say "It hurts when I do this," with the doctor saying "Well, then don't do that." :)
    Seriously, have you tried simulating the same flex conditions in your garage with a drive-on tire ramp or similar? If you can get the sound to repeat, you might get a hint about the problem by looking around under the truck.
    Of course, be careful while doing this. You probably don't want to get ran over by your own truck while trying to identify a sound coming from it.
  8. Sep 11, 2012 at 2:31 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Could be stress in the sheet metal rubbing from the pinch weld area. I had this on my truck and have since solved it.
  9. Sep 11, 2012 at 2:44 PM
    Toytrd12
    Toytrd12 Member
    Frostburg Md
    2012 trd Offraod
    Stock
    My 12 was doing the same thing ,except its all stock suspension.It use to only happen when the truck was turning and it was flexing out pretty good.I took mine to the dealer and they couldn't find anything wrong.It was doing it with 170 miles on it , it now has about 13xx and the noise is completely gone.Sorry I'm not any help my noise just went away.
  10. Sep 11, 2012 at 2:45 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If you think it is coming from the rear, double check the torque on your u-bolts.
