Popping sound when turning hard left.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddy, Mar 18, 2020.
  1. Mar 18, 2020 at 10:19 AM
    Reddy
    Reddy [OP] Well-Known Member
    Scott
    Ohio
    '11 TRD OR AC
    OME 885's/Dakars/265's/belly skid
    Did a low speed U turn today and got a “pop.... pop.... pop....” from my front end. Was able to replicate it in the driveway when turning hard left. Turning right doesn’t make a noise and it only makes the noise while in motion.
    My first thought was a bad CV joint, but correct me if I’m wrong, would a CV joint not make that noise when not under power (ie, not in 4x4)?
    Also, would a bad needle bearing cause that noise? I installed a lift with OME 885 coils and Dakar’s about a month ago, so needle bearing problems wouldn’t surprise me.
    I’m just trying to figure out what parts to order, but am a little confused at the moment.
    wilcam47 likes this.
  2. Mar 18, 2020 at 10:23 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Retorque the lower shock tower bolts, as well as the UCA Bolt, and all 4 LCA Bolts
  3. Mar 18, 2020 at 10:56 AM
    Zjustin28
    Zjustin28 Well-Known Member
    Id be curious of your CV angle. a CV shaft can in fact pop like that even in 2wd.
  4. Mar 18, 2020 at 11:03 AM
    eon_blue
    Azusa, CA
    I don't know what 2nd gen steering racks are like, but when my 1st gen steering rack guide got over tightened it created a really gnarly POP POP POP when turning left only. Backing off the torque on the rack guide a bit got rid of it entirely.
    If you haven't messed with the rack guide at all then I doubt this would be the case, I'd be checking all bolts on that side and see if your tie rod has any slop to it.
  5. Mar 18, 2020 at 11:11 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    How many miles? Yes they can make noise out of 4wd if worn
  6. Mar 18, 2020 at 11:37 AM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    Nah, haven’t messed with the rack at all so I don’t think it’s this. But... there’s slop in both CV’s, drivers side especially, making them all the more suspect.
    Angles aren’t bad at all. I’m wondering if a joint wasn’t on its way out anyway and being at a slightly new angle was just the straw on the camels back.
    I really was hoping it was this simple but everything’s tight. Guess it’s a CV axle after all. Thanks guys. Unfortunately it’ll be next weekend before I get a chance to tear into it.
  7. Mar 18, 2020 at 11:38 AM
    Zjustin28
    Yea if they're sloppy i think you've found your culprit.
  8. Mar 18, 2020 at 11:40 AM
    eon_blue
    Azusa, CA
    How much play in the CVs? Some play is normal esp on the drivers side. But too much is a problem.
  9. Mar 18, 2020 at 11:40 AM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    Sounds like a ball joint gone bad to me
  10. Mar 18, 2020 at 11:43 AM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    65k miles, wouldn’t have thought a CV could go that low, but who knows.
  11. Mar 18, 2020 at 11:44 AM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    Then it would do it without the vehicle having to be in motion, right?
  12. Mar 18, 2020 at 11:48 AM
    1taco2motos
    Colorado
    I suppose it's possible to make a ball joint pop while stationary but usually the vehicle has to be in motion to make it pop
  13. Jun 10, 2020 at 5:01 PM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    Man enough to admit when I'm wrong, but sure enough, the driver's CV was all tore up. Replaced it and did the ECGS bushing at the same time.
