Popping sound when turning
Discussion in '1st Gen. Tacomas (1995-2004)' started by mat, Apr 15, 2011.
  1. Apr 15, 2011 at 2:31 PM
    mat
    mat [OP] Well-Known Member
    01 prerunner sr5
    elite offroad front bumper, tool box, rustoleum bed liner, fog lights, alpine head unit, homemade bed extender
    When i first bought my truck it would always make a popping sound when i turned right. I assumed that it was just a quirk of the truck and learned to ignore it. After i had it for about a month, it started leaking oil so i took it to the dealership since it was still under warranty. They said it was leaking oil because someone had not put the oil filter on correctly. After that the popping stopped. I do not know if that is what made it stopped, but it did. However, about a week ago it started popping again. At first it was only when i turned right, now it is when i turn left too, and when i make tight turns it kind of creaks. I have a spacer lift on the front that the truck came with when i bought it, it is still under warranty, but does anyone know what it could be? Thanks alot
  2. Apr 15, 2011 at 3:30 PM
    pickuptruckguy
    pickuptruckguy Well-Known Member
    SoCal
    04 Doublecab 4x4
    ball joints? You never want to crank the steering wheel all the way. If you hear the power steering pump bog down, your turning the wheel too far.
  3. Apr 15, 2011 at 5:35 PM
    ttran
    ttran Expert Mallcrawler
    Tim
    Charlotte, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    Could be the cv axle
  4. Apr 15, 2011 at 9:41 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    I read "it is still under warranty" That means, drop it off and the stealership. I had a popping sound time to time, oh nvm... I have a SA :p Anyway. Stealership.
  5. Apr 16, 2011 at 10:19 AM
    mat
    01 prerunner sr5
    pickuptruckguy im not turning it super hard and i dont feel it bogging down it will pop when the wheel is about halfway turned. And arent cv axles only for 4X4s?
  6. Apr 16, 2011 at 10:46 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    yes, is it popping while moving or popping while turning the wheel?
  7. Apr 16, 2011 at 12:46 PM
    pickuptruckguy
    SoCal
    04 Doublecab 4x4
    oh, gotcha, I misread. I agree w STT, take it back to the dealership. It's obviously not the oil filter:D
  8. Apr 16, 2011 at 12:51 PM
    mat
    01 prerunner sr5
    yea i didnt think it was the oil filter it was just weird that that seemed to get rid of the noise before
  9. May 11, 2011 at 3:19 PM
    mat
    01 prerunner sr5
    the popping sound randomly stopped for a couple of weeks, but now it is back again and is much worse, it has also started to creak intermittently during low speed turns. I want to take it to toyota since i have a warranty, but i doubt that they will honor it
  10. May 11, 2011 at 3:25 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    Maybe they put it on a rack to check it out and it extended your suspension, temporarily changing an angle and relieving the issue for a bit. Once everything settled back in and you turned hard again, the issue may have come back.
    I have a similar issue that only happens when I back up and turn the wheel hard to the right. If I come to a hard stop after backing out of a parking space with the wheel fully turned, I get a little "pop" sound but I've had everything checked and it all looks good by 2 different shops and another personal expert.
  11. May 11, 2011 at 3:38 PM
    mat
    01 prerunner sr5
    yea but this is starting to get worse, at first i didnt notice it over the radio, now i can always hear the pop, and i wouldnt bother me that much if i knew what it was. I just dont want it to be something serious that i dont know about, i was thinking it might have something to do with the extra weight of my elite bumper or the spacer that came with it when i bought it. But i feel like they would try and say the spacer caused it and wouldnt honor the warranty
  12. May 11, 2011 at 3:43 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    I have a pop as well and can feel it in my floor board. Someone mentioned that it could be sway bar bushings. I havent checked them yet, but next time it goes up on a rack, I'm checking them.
  13. May 11, 2011 at 3:45 PM
    mat
    01 prerunner sr5
    oh ill have to check that out, alot of people just remove the sway bar right, if i were to remove it completely and the bushings were the problem would it stop it?
  14. May 11, 2011 at 4:12 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Yes because they wouldnt be there anymore but i dotn think that the bushings are the problem it sounds more like some kind of joint to me. How is your alignment?
  15. May 11, 2011 at 4:16 PM
    mat
    01 prerunner sr5
    should be fine on the alignment, no shaking at any speeds and i havent had the truck that long either and it showed all of that type of maintenance had been done on the carfax. i was thinking it was a joint, and the creaking was something with the suspension
  16. May 11, 2011 at 4:18 PM
    mat
    01 prerunner sr5
    also it does this when im stopped too
  17. May 11, 2011 at 4:32 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I forgot about the creeking, but that sounds about like something with the suspension.
    I was going to say if the alignment was a little off maybe it was a tie-rod or something of that nature, maybe check the balljoints but idk why they would "pop" when turning that would be more fo a hitting a bump situation
  18. May 11, 2011 at 4:35 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    I have my sway bar removed and it still occasionally makes that pop when I back out and turn the wheel hard right. It's a very light pop almost like a tire is catching on an edge of plastic, but I've trimmed and nothing should be catching.
  19. May 11, 2011 at 5:04 PM
    HUNT
    HUNT Well-Known Member
    Tommy
    Wildwood Ga
    2003 Double cab 4x4
    Bilstein 5100 set @ 0, OME 881,Wheelers 5-leaf, OME NitroCharger Sport shocks, 4-RUNNER LIMITED WHEELS, Duratracs, 265/75/16
    My 4-runner made the same poping noises.....After replacing the steering rack ,and upper and lower ball joints it ended up being the sway bar bushings........
  20. May 11, 2011 at 6:49 PM
    mat
    01 prerunner sr5
    ok im glad to know this isnt really uncommon. Seabass, it is just like that, it sounds like im driving over a coke bottle, the creaking doesnt bother me as much cause i was pretty sure that it was the suspension, and im sure that the springs are getting worn out, since they are ten years old, i know that taking the swaybar off effects handling, but how bad is it, and what is the removal process?
