Popping sound
Discussion in 'Technical Chat' started by dawgn86, Sep 10, 2016.
  1. Sep 10, 2016 at 10:12 AM
    dawgn86
    dawgn86 [OP] Well-Known Member
    2013 Toyota Tacoma
    Hi all
    2013 4cyl with 40k miles. Automatic. Crew cab. When coming to a stop from slow speed I'm hearing a popping sound in the front right side near / behind the wheel. Does this in reverse as well. Jacked it up, removed tire. Brakes looked Good. Caliper tight.
    What else should I look for?
  2. Sep 14, 2016 at 8:54 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Is it 4x4? If so check cv axle, also check tie rods, ball joints, sway bar bushing etc..
