Portable air compressor - input
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WhiteTaco82, Feb 17, 2019.
  1. Apr 27, 2019 at 3:38 PM
    #121
    cricketfire46
    cricketfire46 If it ain't broke, I can change that TTC#231
    Daniel
    Gilmer TX
    2019 DCLB OR
    Pardon my ignorance regarding this, just today I had a trailer tire issue so was already planning on asking about this when it popped up in recent, are these viair systems hardwired or plugged in? I wanted onboard air since I had my jeep but now it's happening soon. If I read through this correctly, if I were to run a setup like the 88P or 400P with the only usage being tires, I should not need a tank, correct? Sorry for all the questions, I've always used cheap plug in compressors and they typically didn't last more than a couple of uses. I don't need it often but it's higher on the list of things I need now.
    FlavorChef7 likes this.
  2. Apr 28, 2019 at 7:00 AM
    #122
    huachuca
    huachuca Well-Known Member
    Al
    Tarboro, NC
    2012 4WD DC w/TRD offroad
    The 88P and 400P connect directly to the battery via alligator clips. I suppose you could hardwire these but the pump would need to be mounted in a location that would provide reasonably good protection from dirt and water. A tank of sufficient size is useful for running air tools or re-seating a bead but isn't necessary for refilling tires although it will make the process somewhat quicker.
  3. Apr 28, 2019 at 7:07 AM
    #123
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Do you guys think the viair on board air is worth it when compared to something like the 400p? I would imagine the tire will fill up faster but at twice the cost I wonder if it’s worth it.
  4. Apr 28, 2019 at 8:37 AM
    #124
    timlovestacos
    timlovestacos Well-Known Member
    Tim
    Orange County, CA
    2018 TRD 4x4 OR Silver
    If you’re just filling tires the minute or two you would save with an onboard air wasn’t worth it to me. Plus the portable stays out of the elements and tucked away in the truck, so it last much longer (I’ve had mine going on 7 years now). Everyone has their own wants and needs though so at the end of the day if you want onboard air get it!
    Bluegrass Taco and huachuca like this.
  5. Apr 29, 2019 at 5:18 AM
    #125
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
  6. Jun 12, 2019 at 9:47 AM
    #126
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    So I'm looking at getting a 300p and hardwiring it in the engine bay. Is the verdict that these need to be covered up when not in use to protect from dirt/water/mud etc? And if it's being hardwired, I need to wire in a switch to turn it on and off? Still a bit confused after going through all 7 pages, ha.
    Greg.Brakes.Tacos likes this.
  7. Jun 12, 2019 at 12:06 PM
    #127
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    I'm on the fence about the 300 vs 400, as well as the 400 auto...and the concept of perhaps hardwiring off the battery makes me think about getting the auto-hood struts, versus using the hood stand/arm.
    I like your idea/the ideas about hardwiring for the portable 300P/400P series, but am wondering if there would be a way to hardwire to a plug&play setup so you could pull out the compressor and simply plug into the hardwired system, thus avoiding the hood, clips, setting compressor in proximity of clip wires...then the take down process (I guess it's laziness, but I view it as efficiency improvements!).
    Anyone have insight or advice?
  8. Jun 12, 2019 at 12:40 PM
    #128
    Technique
    Alex
    Utah
    I think I saw somebody else post this..but you could maybe use these type of wires/connectors. I don't know if they are rated high enough for the powerdraw of a portable compressor but just an idea. Obviously, you will have to cut the stock wires off and put these on. That way you could leave one end on the battery and quick connect/disconnect as you need.
  9. Jun 12, 2019 at 3:45 PM
    #129
    timlovestacos
    Tim
    Orange County, CA
    If you’re going to hardwire it in the engine compartment just look at the 400H VIAIR offers. It’s already made to hardwire and similar to the 300, with more CFM and faster fill times. At the end of the braided steel hose is a male quick connect fitting so any open ended hose with an inflation tip will work. Just do t get one with a trigger style inflator.
  10. Jun 13, 2019 at 7:55 AM
    #130
    Technique
    Alex
    Utah
    Damn, I already ordered the 300p (arriving today, gotta love 1 day prime shipping) and the 400H wasnt on prime shipping... I'll probably just end up using the 300p..hardwiring it would just be cutting the battery clamps off and soldering on some battery terminals on right?
  11. Jun 13, 2019 at 7:57 AM
    #131
    timlovestacos
    Tim
    Orange County, CA
    Yea that’s ok. Just know the 300P is only IP54 rated so keep it to minimal exposure somewhere. I’ve seen it done hundreds of times though so I wouldn’t worry much!
  12. Jun 13, 2019 at 8:00 AM
    #132
    Technique
    Alex
    Utah
    Yeah, I'll probably make some sort of a cover for it so it doesn't get exposed to dirt/water that much in my engine bay.
    timlovestacos[QUOTED] likes this.
  13. Jun 13, 2019 at 9:46 AM
    #133
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    That's a good cost effective option, I was just trying to avoid hard mounting the compressor in the engine bay...and was thinking more of having the ability to simply replace the gator clips with a ring terminal connection at the battery, then splicing in some type of "plug and play" connector that the actual portable air compressor...
    Basically so I can store the air compressor in the back of the double cab cubby, but only have to connect the pump wire to the plug and play (both ends would be spliced with connector, versus going to open hood and clip on the battery.)
  14. Jun 13, 2019 at 9:48 AM
    #134
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    @timlovestacos do you happen to know what gauge wire is used on the gator clip wiring?
    timlovestacos likes this.
  15. Jun 13, 2019 at 9:49 AM
    #135
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    So you want an expensive one then?
  16. Jun 13, 2019 at 11:56 AM
    #136
    timlovestacos
    Tim
    Orange County, CA
    I want to say 12 but it could be 16. Either way I would do 12 to be safe.
  17. Jun 13, 2019 at 12:25 PM
    #137
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    I think, at least initially will just run the alligator clips...but figure running the power via hardwiring and splicing a plug (male and female)...but perhaps this endeavor is far more trouble than it seems (at least in my head!):frusty:
  18. Jun 13, 2019 at 1:26 PM
    #138
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    Along those lines, I bought a Milwaukee air inflator for my mountain bike and have used it to air up all four truck tires after a run a couple of times now. I was going to get onboard air but am seriously reconsidering it.
  19. Jul 6, 2019 at 3:47 PM
    #139
    cricket1116
    cricket1116 Mediocre Triathlon Enthusiast
    Robert
    2019 SR - TSS Package
    Hey guys, for those of you with a double cab, do your compressors fit in the storage space behind the rear seats? Primarily interested in the Viair 300/400 models, but interested to see if any fit back there.
  20. Jul 7, 2019 at 6:34 AM
    #140
    timlovestacos
    Tim
    Orange County, CA
    I couldn’t get my 400P-Auto to fit back there. I just tuck it behind the front seats on the floor or in the bed (under the cover).
