Portable, battery powered welders (stick or MIG).
Discussion in 'Garage / Workshop' started by coff33, Jun 5, 2022.
  1. Jun 5, 2022 at 6:51 AM
    coff33
    coff33 [OP] Well-Known Member
    5vzfe manual
    What are my options? I know there is the Fronius Accupocket, but want to know about less expensive options if there are any.
    Goals: Ability to do medium duty welds offgrid. Short duty cycles are okay.
  2. Jun 5, 2022 at 6:56 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Miller has a portable MIG kit. Not battery operated. F150 not included.
  3. Jun 5, 2022 at 7:01 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Interesting. Amazed.
    What voltage and current?
  4. Jun 5, 2022 at 7:03 AM
    coff33
    5vzfe manual
    I'm new to welding. Whatever is needed to weld upto 1/8" mild steel in a single pass.
  5. Jun 5, 2022 at 7:05 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Jumper cables and welding rod. Will need at least 2 or 3 car batteries
  6. Jun 5, 2022 at 7:22 PM
    ksJoe
    ksJoe Well-Known Member
    Joe
    Kansas
    2020 TRD Off-Road
    If you need to do this frequently on many occasions, then a battery powered welder is probably justified. But I'm not familiar and can't help there.
    If you aren't planning on doing this with high frequency, I would recommend an AC powered welder and a generator. I had a Hobart Handler 140 (120v mig welder) for around 10 years and wil do 1/8" easily in a single pass. To run it full power it needs 20 amp, 120v, which is well within the capability of a small (but not tiny) generator. I sold my Hobart 140 and bought the Hobart 210 mvp. mvp = multi-voltage-plug. If its plugged into 120v, its basically like the Handler 140. If its plugged into 240v, it's a 210 amp mig welder capable of welding aluminum. These are just a couple examples, but my point is: look at a quality 120v mig welder.
    If you buy a quality battery powered unit, you'll spend a lot of money and have something that is forever limited by a battery. You can't weld longer than the battery life, and those batteries are expensive and don't last forever. Your needs easily fit within the capabilities of a small AC powered welder. If you go that route, you'll have a lot more capability, and not be limited by a battery.
    I'm assuming you can drive your eqiupment to the work site, and it will be a rare enough occasion that hauling a small welder and a small generator isn't a big deal. If either of those assumptions is incorrect, go for a battery powered unit.
    Mark77 likes this.
  7. Jun 9, 2022 at 7:12 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your best and cheapest set up would be a used generator and small used 120VAC welder self shielded wire and lots of practice out of position.
    Define medium welds to me that means under 3/8".
    The Better battery powered welders are made for that niche market in the Big City where you need to go up 30 stories and weld 2 brackets .
  8. Jun 9, 2022 at 7:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    1/8" is pretty thin still.
    Why is doing it off grid a requirement?
    As mentioned above, a 120v welder will easily take care of that.
    If you really need a strong weld for on the budget, some 6010 or 7018 rod and jumper cables.
  9. Jun 9, 2022 at 7:18 PM
    Bivouac
    I gotta try battery powered stick welding see if it is feasible 3/32" 7018 I have never had to.
  10. Jun 9, 2022 at 7:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'd think running 2 car batteries (done it once to show my co-worker) is best used with 1/8" rod.
    I've only used 3/32" (and smaller, or larger than 1/8") on an actual welder and that stuff burns quick even at a much lower setting. The car battery welding was only 1/8"
    Bivouac[QUOTED] likes this.
  11. Jun 9, 2022 at 7:25 PM
    Bivouac
    I can try all 3 and 3 sizes of 6010 one has to hit the sweet spot!
    Kwikvette[QUOTED] likes this.
  12. Jun 9, 2022 at 7:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I've done 7018 overhead; can't imagine only having 6010 and having to run overhead (under the truck).
  13. Jun 9, 2022 at 7:26 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    This was field welded with 1/8" 6010 with two batteries. After 3 of 4 LBJ bolts snapped I welded that fucker good. Then I wheeled it like that for another 3 months. If you wheel hard you better have a field weld kit for shit like this.
    Kwikvette likes this.
  14. Jun 9, 2022 at 7:30 PM
    Bivouac
    Those days for me are long in the past.
    Now I just fix others peoples mishaps.
  15. Jun 9, 2022 at 7:32 PM
    Bivouac
    6012 I have all kinds of interesting electrodes around.
  16. Jun 9, 2022 at 7:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    6010, 6011, 6013, 7014, 7018, 7024, and 308L are rods I've run.
    308L (stainless) runs just like 7018 does; it's so nice. But much more finicky with angles (more due to the stainless itself).
    Never ran 6012.
  17. Jun 9, 2022 at 7:49 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Here's the one I've been eyeballing. A tad spendy but have seen them in use by the military in hummers, they work well. The company has lower cost build to fit options also.
  18. Jun 9, 2022 at 7:55 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
  19. Jun 9, 2022 at 7:59 PM
    Bivouac
    Interesting but you are also getting a Higher output alternator I don`t think OP wants that much of an investment.
    I need to explore this more.
  20. Jun 9, 2022 at 8:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No confusion.
    A very budget-friendly solution was offered.
    A few others (not super expensive but not exactly cheap) were offered as well.
    Considering the OP is new to welding, I'd suggest he/she takes a course to learn the basics...or learns from a proficient welder.
    Still curious as to why off-grid is important?
    OP has posted various threads on the most basic of things relating to auto maintenance (in general) and basic Tacoma stuff.
    Bivouac likes this.
