Portable Jump Starters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thektbird, Jan 25, 2021.
  1. Feb 1, 2021 at 8:19 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I bought an anti-gravity a few years ago for my enduro since there's no kickstart. I've used it on my tacoma once and the neighbors nissan about a half of a dozen times. Charged the kids videogame, my wifes phone and started my moms sierra 5.7l. I'm really impressed with mine.
  2. Feb 1, 2021 at 10:13 PM
    rb9228
    rb9228 Well-Known Member
    Yuma, AZ
    2014 Tacoma TRD OR
    After watching Project Farm comparison on YT a while back, I picked up an Audew Starter
  3. Feb 2, 2021 at 3:57 AM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    After sitting in my truck for over a year I finally had to use my GB40.
    Not on my truck, but a Chevy truck with a 5.3. The truck battery was so dead there were no lights or buzzers at all. The Noco started it right up. Very impressed.
  4. Feb 2, 2021 at 11:05 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I am also impressed how long they hold their charge. A few times I used it, thinking there's no way there's any juice left. But sure enough, started.
  5. Feb 2, 2021 at 11:11 AM
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    for those letting these sit in vehicles for extended periods, is cold weather affecting it? One of these could come in handy, but if I have to bring it into the house every day its honestly just not going to happen. And im talking COLD weather, high this coming Sunday is -7, low of -19 overnight.
  6. Feb 2, 2021 at 11:14 AM
    forana
    Kaneohe, Hawaii
    I'm in Hawaii so I dunno about cold weather. Mine was in my truck for over a year at least and still jumped a car.
  7. Feb 2, 2021 at 11:18 AM
    Yellow Bang
    Yellow Bang Active Member
    Derek
    2014 Tacoma
    I used an IdeaPlay I got off of HSN for around $70bux. Worked well last time I needed it!
  8. Feb 2, 2021 at 11:29 AM
    GSDLVR123
    GSDLVR123 Well-Known Member
    Randall
    2023 TRD Pro (Solar Octane)
    I have a couple GB40 and 4 GB70 chargers...both work well, I keep them in all our kids cars and one in both my wife and my vehicle. I keep one (GB70) in our garage for tractors and such. I carry the GB70, just in case I need extra power for a larger vehicle while I'm on the road. I think the GB70 is the better buy. My daughters have GB40s but I plan to replace them for GB70s (both of their vehicles are V8s). ***My oldest had to jump her V8 once (battery went bad prematurely) and the GB40 did it.
  9. Feb 2, 2021 at 11:37 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    https://www.amazon.com/gp/product/B01GQDBNWS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    I realize it's bigger (and pricier) than anything others have listed, but this one filled a need. Jump starting was secondary. With that said, I think I've used it to jump start more than the other reason I got it. I love it. Voltage display. Charge display. A little work light. The leads have great length and store easy. Cigarette light plug and two USBs. That's all I need.
  10. Feb 2, 2021 at 12:00 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    I still have a Wagan Power Dome LT that has been jumping batteries and airing up tires for ten years. It's lunchbox size (lead acid) but strong and reliable. Used it two days ago for a slow leak and hadn't had it on a charger for about nine months. Tried a Rugged Geek Lithium jump/compressor combo, not impressed, didn't have sustained cranking power despite good specs. I've seen the same with Lithium jumppack tests with various brands.
    The old Wagan lead acid just keeps performing.
  11. Feb 6, 2021 at 7:17 AM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    Same here. I live in so cal so not very cold but it advertised a 6 month charge hold. Mine sat for over a year and still worked with no issues. Since then I try to stay diligent on giving it a charge at least every six months, just in case. Size wise its thicker than my cell phone but about the same size. Fits in the side pocket of my ride bag when we go to the desert or mountains
  12. Feb 13, 2021 at 10:34 AM
    mOjO_Taco
    mOjO_Taco Well-Known Member
    Mesa, AZ
    2020 TRD 4X4 OR Cement
    None yet
    I’m hearing a lot about the NOCO on this thread. Any thoughts on this one?
    TACKLIFE T8 MAX Jump Starter - 1000A Peak 20000mAh, 12V Car Jumper (All Gas, up to 6.5L Diesel Engine)
  13. Feb 13, 2021 at 12:51 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I carry one like this.
    I have the older version of it.
    https://smile.amazon.com/Schumacher-DSR132-capacitor-Hybrid-Starter/dp/B07H6BY178
    My wife has a noco in her car.
    Thread reminds me to charge it.
    Been below 0 in Vt I’d bet it’s dead right now.
    I’ve only used mine a few times.
    Hers has been well used.
    The dsr is different to use and won’t build if the donor battery is below 6 volts I think?
    But needs no maintenance charge just a few minutes to build volts from the weak battery.
  14. Feb 13, 2021 at 2:36 PM
    Waasheem
    Waasheem
    2007 xrunner
    The small jump packs are like a car salesman. Promise the world and deliver crap. You can find some videos on guys who’ve actually tested multiple units for amperage delivery. I have 2, tested both. Antigravity put out 75 amps. The smaller Rezervo 232 amps, the smaller rezervo model that is.
    https://www.amazon.com/gp/product/B07GK4PKKD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    https://www.amazon.com/Antigravity-...3255751&sprefix=antigravity+xp,aps,225&sr=8-2
  15. Feb 15, 2021 at 6:39 PM
    #35
    Waasheem
    Waasheem
    2007 xrunner
    I haven’t seen this one before. Nice, it uses both a lithium battery and capacitor.
  16. Mar 12, 2021 at 11:17 PM
    #36
    Waasheem
    Waasheem
    2007 xrunner
    I’m curious if anyone has put a amp clamp on their jumper to see what it’s really putting out. My old antigravity is beginning to look pregnant and besides it kinda sucks. So I’m looking to replace it. I know we’re not thinking about testing the jumper when trying to start a dead vehicle. We’re thinking about getting the dang thing started.
    I had given up trying to find a good jump pack and was planning to make my own when I came across the capacitor type which works pretty good but works better supplemented with the crappy antigravity. I’m a forklift mechanic so sometimes I gotta park somewhere then walk through a warehouse 200 yards. Carrying a 40 lb jump pack that far, my old bones don’t like it.
  17. Mar 13, 2021 at 2:01 AM
    #37
    6 gearT444E
    Deep South
    Herculiner Hootus
    Here have you. Doubt anyone else would search much further.
    Waasheem likes this.
  18. Mar 13, 2021 at 4:56 AM
    #38
    2006whitetacoma
    2006whitetacoma Well-Known Member
    2006 White SR5
    I have the Tacklife T8, haven't got to use on my own vehicle but I did use it to start a 2003 F-250 at work one day.
  19. Mar 13, 2021 at 6:53 AM
    #39
    Waasheem
    Waasheem
    2007 xrunner
    Thanks. Yeah I doubt anyone would cook their starter like that for testing educational purposes.
    6 gearT444E[QUOTED] likes this.
  20. Mar 13, 2021 at 7:38 AM
    #40
    vtdog
    vtdog Well-Known Member
    NH
    My motto with Harbor Freight has always been "If it has a motor, or an engine don't buy", but HF has a number of jump starters. I don't know if they are devices which would fall into being something that should be avoided. So, does anyone have any thoughts on the HF starters?
