No longer available! Portable/picnic kegerator setup (NJ)
Discussion in 'Buy / Sell / Trade - Other' started by JL8Jeff, Sep 20, 2018.
  1. Sep 20, 2018 at 12:03 PM
    JL8Jeff
    JL8Jeff [OP] Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I have a portable kegerator which is a cooler with a tap handle and cooling plate in the bottom. It includes the keg coupler, regulator with lines and CO2 tank. You fill the cooler with ice and hook the keg to the fitting in the side and it pumps the beer through the plate cooler in the bottom. It has some spare O-ring gaskets and spare line but I would either clean the beer lines to the cooler plate or replace them. I will include a new refrigerator that needs to be repaired. I was turning it into a kegerator and drilled one hole in the top of the fridge and hit the only cooling line that goes through the top. So the fridge would need the line repaired and then refilled with coolant, but the compressor is new and should run fine. $125 Located in central NJ and not looking to ship.
    uurx likes this.
  2. Sep 21, 2018 at 5:04 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
  3. Sep 23, 2018 at 4:18 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    HolyHandGrenade likes this.
  4. Sep 23, 2018 at 4:21 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Trailer is FULL!
    Slashaar likes this.
  5. Mar 6, 2019 at 7:42 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    No longer for sale, I donated the setup to my cousin and local firehouse. I'm sure they will get some good use out of it.:D
