Portal axle conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bluegrass Taco, Dec 10, 2015.
  1. May 2, 2023 at 8:56 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    Saw a portal axle on a Marlin RCLT.
    Look for crawlinyota on Facebook.
    The brake caliper was too low imo.
    reallifedog likes this.
  2. May 17, 2023 at 10:58 AM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    The 74weld portals only multiplies your gear ratio by 1.22 (portal ratio). So if you have stock 3.73 gears, your actual total axle reduction is 4.55 so basically the same as re-gearing to 4.56 without portals. Seems like they'd be perfect for bolting onto stock height suspension and slapping 35s on but you have ground clearance of running 40s or 42s. Would be really cool to get the price on them down enough to make it easier to chew on. I know those Werewolf 4x4 portals are around 15k. 74weld are like 25k
  3. May 17, 2023 at 11:04 AM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    Was that a confirmed price? I’ve seen people float that price around but I haven’t seen it in their website.
  4. May 17, 2023 at 11:36 AM
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I haven't either, just guessing wildly haha
  5. Jun 9, 2023 at 2:30 PM
    jeisfoto
    jeisfoto Active Member
    Midwest
    '20 DCSB OR
    Dobinsons MRA, AG + 12” smoothies, Deaver Stg 2, 4.88s, 35s, tuned...
  6. Jun 12, 2023 at 10:31 AM
    harrytasker
    harrytasker Well-Known Member
    I am not even crazy enough to spend 20 grand on these. I was expecting they would be in the 15k range.
    There is value in these given that with just the portals you can run 35's, but you still need better shocks, UCA's, and springs.
  7. Jun 12, 2023 at 5:50 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Just more shit to break.
  8. Jun 13, 2023 at 11:07 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    that could be said about anything you add to your vehicle. Given the price, it seems unwarranted, but if it were in the 5K price tag it seems that you could get a decent lift and avoid a regear it would be worth it. And being that it gears things down and eliminates drivetrain stress the only thing really that sees the most abuse is the hub gear so as long as you carry a spare you’re in the clear.
