Porter Cable 7424 Question
Discussion in 'Detailing' started by jesseh, Dec 19, 2010.
  1. Dec 19, 2010 at 10:06 AM
    jesseh
    jesseh [OP] Member
    Keller, TX
    07 TRD
    Was wondering if polishing with the porter cable 7427 will damage the TRD decal?
  2. Dec 19, 2010 at 10:51 AM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    it depends more on the pad, pressure and product you are using. if you were using, for instance, optimum poli-seal and a white or softer pad, no, but if you were using an orange pad and optimum polish or compound...possibly. you don't want anything hot or abrasive on the decal - it is soft vinyl.
  3. Dec 19, 2010 at 11:25 AM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    ^^^ is right. Just use light pressure, and a non-aggressive polish, and you'll be fine.
  4. Dec 21, 2010 at 2:05 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Yep. ^^^^^^^^^
  5. Dec 22, 2010 at 5:58 PM
    RobZ71LM7
    RobZ71LM7 Member
    Mount Washington, KY
    09 Tacoma Reg Cab, 2.7L 5-speed
    I tape any decals or trip off with masking tape if I'm using any compound or polish with abrasives.
  6. Dec 22, 2010 at 6:21 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    solid policy. decals, emblems, edges and trim.
  7. Dec 22, 2010 at 6:22 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    If you want to be super-careful, just avoid the decals. It's not like you can may the decals any more shiny than it already is.
  8. Dec 22, 2010 at 6:25 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    x2 just go around them, problem solved...
  9. Dec 23, 2010 at 8:24 AM
    RobZ71LM7
    RobZ71LM7 Member
    Opps I said "trip" instead of trim. Anyways another reason to tape off trim is that black rubber trim, especially if dressed, may still hold some dirt and grit after washing. Bump into it with your pad and you've picked up the dirt and are now marring and swirling your paint. I only tape off edges if using something more aggressive like XMT#4 or Meguiar's #105. Decals and emblems can be dulled by abrasives. It only takes two minutes.
