Portland Area Gear Installation
Discussion in 'North West' started by lightnfast, Dec 31, 2019.
  1. Dec 9, 2020 at 8:55 AM
    #121
    bfaris1
    bfaris1 Well-Known Member
    Brian
    2018 White TRD OR
    6112 #700/5160 w/ Wheeler’s AAL RCI Skids Front to back RCI sliders SSO Slimline (Hi-clearance soon) Sungtop Various other crap
    @thedriza did you end up getting 5.29’s done at paden’s?
  2. Dec 9, 2020 at 9:13 AM
    #122
    bfaris1
    Brian
    2018 White TRD OR
    Quick review on Paden’s and Nitro 5.29’s:
    let me start by saying the do stand by their work but ultimately I’m unsure if they are doing something wrong to nitro gears are having an issue but my gears are loud. It’s in the coast and in certain speed zones. Mike has redone the rear and twice now and set the preload differently and it moves where the sound falls but always some on the coast. I think mike does good work but ultimately I think he is having trouble setting the correct pre load on my gears. Also since done, my previously installed edge bushing is giving me the same vibrations as my spider bearing. Truck drives much better but the gear issues are making it feel more like an ol POS than a 2018 should. Ultimately I may drive to nitro in cashmere to have them diagnose. They gave good reviews about mike and padens themselves but ultimately something isn’t right
    If anybody else is having similar issues it’d be great to hear from you. I also have a grinding feel when coasting from 70+ down
    rlx02 likes this.
  3. Dec 9, 2020 at 9:28 AM
    #123
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Did you give those gears time to properly break-in?
    This report is mildly concerning, I want to use them for a re-gear in the near future..
  4. Dec 9, 2020 at 10:04 AM
    #124
    bfaris1
    Brian
    2018 White TRD OR
    I did a proper break in each time which trust me was very frustrating doing 1500 miles of break in
    if you’re doing 4.88’s or 4.56’s he seems to have those pretty dialed in
  5. Dec 9, 2020 at 12:19 PM
    #125
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    What kind of fluid are you using? Maybe try something with higher viscosity. I swapped Mike's oil out at break-in for something thicker.
  6. Dec 9, 2020 at 3:03 PM
    #126
    bfaris1
    Brian
    2018 White TRD OR
    I’ve been using the Dino 85-140 the whole time. The echo recommended stuff
  7. Dec 9, 2020 at 9:15 PM
    #127
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    @Alfasin
  8. Jan 11, 2021 at 12:41 PM
    #128
    Bigheadedbilly
    Bigheadedbilly Member
    2020 Tacoma TRD OR
    update
  9. Jan 14, 2021 at 8:55 AM
    #129
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    hmm....may hold off on the gears until later. I think the huge rush of customers since word got out on the street about their pricing may have affected their quality.
  10. Jan 15, 2021 at 10:16 AM
    #130
    bfaris1
    Brian
    2018 White TRD OR
    again after dealing with mike multiple times I wouldn’t say it’s his quality. Toyota axle seals are known to be weak when removing axles and he is up front that he doesn’t do a ton of air locker installs so the issues that have been stated make sense. The issues really are coming down to gears themselves. More people have this issue with noisy 5.29 nitros than I think is stated on here
    lo2hi and rlx02[QUOTED] like this.
  11. Jan 15, 2021 at 10:16 AM
    #131
    bfaris1
    Brian
    2018 White TRD OR
    still waiting for revolution to have gears in stock so I can get them in will update when things get done
  12. Jan 19, 2021 at 2:26 PM
    #132
    bfaris1
    Brian
    2018 White TRD OR
    Another place I’ve been recommended was six states in the Portland area. More expensive I believe
    rlx02 likes this.
  13. Feb 9, 2021 at 5:04 PM
    #133
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    How are your gears doing? Would you still go back to Paden or spend the coin at JD? I got a quote from Mule, but over 1k more than Paden. I don't want to have to drive down back to Portland leaking fluid the whole way down if anything goes wrong.
  14. Feb 11, 2021 at 7:13 AM
    #134
    kmorgan3
    Kyle
    PNW
    My gears are great. I’ve had them on for about 7,000. Had a minor leak in the front diff that they fixed for free about 4,000 miles ago but otherwise they’ve been solid. I wouldn’t recommend them for an air locker install (he’ll even tell you he doesn’t like them), but for just gears they’re great.
  15. Feb 11, 2021 at 2:25 PM
    #135
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    It seems like more than a few people have had to go back to him for issues. I was considering him, but idk now. I do know there is no way I'm going to mule, their prices are bananas.
    rlx02 likes this.
  16. Feb 11, 2021 at 10:09 PM
    #136
    Kona_boy
    Kona_boy Well-Known Member
    Kent
    2017 White TRD OR
    How was was mule asking? I starting to price around for this
  17. Feb 11, 2021 at 10:47 PM
    #137
    Jasonstacoma
    Stock
    I think ballpark I remember hearing 3k.
  18. Feb 12, 2021 at 9:59 AM
    #138
    Jon@Mule
    Jon@Mule Well-Known Member
    Jon
    Issaquah, WA
    2001 Tundra Limited
    35" MTR's, 4.88's , Air Locker front and Rear
    Mule uses full master install kits on all gearing jobs. We do not re-use bearings, or use mini install kits. We also offer a 12 month 12,000 mile warranty on labor. Once you have completed the gear break in you would come back to drain the diffs and refill at no charge. We only use Schaeffer's synthetic gear oil. Our prices are not out of line with most of the other shops in the area, and you are not traveling several hours to have any issues taken care.
    Belgian Taco, rlx02 and NWTacoTime like this.
  19. Feb 13, 2021 at 2:22 PM
    #139
    bfaris1
    Brian
    2018 White TRD OR
    They’re not out of line with shops in the area but compared to shops along the west coast, PNW prices are a little ridiculous even considering master install kits. @rlx02 my gears are doing wel I just wouldn’t go nitro again. I’d strongly suggest you check out revolution gear or Yukon. Just my 2 cents. Another one in the Portland area is six states. My quote from them for just labor for the rear diff only was around 500 I believe. Not terrible but not great.
    lo2hi and rlx02 like this.
  20. Feb 14, 2021 at 9:22 PM
    #140
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I agree with what Jon said. I got quotes from 3 different places in WA and they're all roughly the same price. The benefit with Mule, if you're in King County, is that you dont have to drive super far like to cashmere to get it done.
    Jon do you guys carry any other gears or is just Nitro?
