Position of 2 studs/nuts vs 10 bolts in bottom oil pan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Dec 2, 2021.
  1. Dec 3, 2021 at 11:34 PM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    It looks like an aftermarket gasket with 3 tubes of the same sealant.
  2. Dec 4, 2021 at 7:34 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I got it from RockAuto a few months ago. The listing didn't specify any imperfection or any out of the ordinary application
  3. Dec 4, 2021 at 11:39 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Factory doesn't use a gasket only FIPG.
    6 gearT444E and TnShooter like this.
  4. Dec 4, 2021 at 6:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Don't use both, it will end up being a mess. Factory uses silicone only, stick with that
    foampile[OP] and TnShooter like this.
  5. Dec 4, 2021 at 9:23 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Are you the original owner of the truck? If not, I'm wondering if the oil pan has been removed before.
  6. Dec 5, 2021 at 7:42 AM
    foampile
    Mid-Atlantic
    OK
  7. Dec 5, 2021 at 7:50 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Is the torque value for the attaching hardware significantly different for FIPG versus a solid gasket?
    foampile[OP] likes this.
  8. Dec 5, 2021 at 7:52 AM
    foampile
    Mid-Atlantic
    Good question. The book says 80 in/lbs for the bolts and 84 for the nuts. I do wonder if too much torque might squeeze the goo out or if you should do it in two stages where you apply minimal torque until the goo solidifies and then do the rest.
  9. Dec 5, 2021 at 7:52 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Same torque.
  10. Dec 5, 2021 at 7:54 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Interesting…I have questions but, pressing the I believe button.
  11. Dec 5, 2021 at 7:56 AM
    Knute
    Generally, with RTV the fasteners are pulled up to finger tight. The RTV is allowed to cure, then to final torque.
    Read the directions on the tube of goo.
    The purpose of torque levels on fasteners is to "stretch" the fastener to develop the clamp load to hold the parts together.
    Once upon a lifetime ago, I was in Industrial Air Compressors as a mechanical engineer. A critical step in the design process was determining the clamp loads and torque levels to hold the valve plates, heads and cylinders together with heat, air loads and vibration. The process was the same with gaskets or RTV.
    BTW, all the calcs are a bit fuzzy. I always used them as a guide. Testing would verify if the torque level was proper.
  12. Dec 5, 2021 at 7:57 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    80 in/lb sounds about right. Yes most of the goo will get squeezed out but some of it will stay where it's needed, filling in the gaps between the 2 metal surfaces. That's how silly-cone works.
    foampile[QUOTED][OP] likes this.
  13. Dec 5, 2021 at 7:57 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    That’s exactly what I was getting at.
  14. Dec 5, 2021 at 7:58 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    There we go, that answers the question. Final torque values being the same
  15. Dec 5, 2021 at 8:02 AM
    #35
    foampile
    Mid-Atlantic
    @b_r_o seems to disagree
  16. Dec 5, 2021 at 8:33 AM
    #36
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    The ultimate arbiters would be the FSM and the instructions on the sealant.
  17. Dec 5, 2021 at 8:34 AM
    #37
    foampile
    Mid-Atlantic
    The FSM/Haynes are often obscure and not specific enough
  18. Dec 5, 2021 at 2:18 PM
    #38
    burrito782
    08 TRD Off Road
    Pretty straight forward (besides the nut torque typo, should be 7.4 ft*lbf as correctly shown in the component breakout snapshot)...
    Jimmyh likes this.
  19. Dec 5, 2021 at 2:26 PM
    #39
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    It’s somewhat vague here but I’m inclined to translate this as apply the sealant, install the pan, install the bolts/nuts and tighten/torque immediately. Nothing about waiting for the sealant to set up.
    Wonder what the instructions on the OEM packing say.
  20. Dec 5, 2021 at 5:37 PM
    #40
    Jimmyh
    SC
    2012 Prerunner SR5
    Exactly.
