Positive camber help
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Dec 9, 2010.
  1. Dec 9, 2010 at 7:14 PM
    2004Taco
    2004Taco [OP] Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Magnaflow and Deckplate Mod Billet grille
    Installed my coilovers, now i have positive camber. Any ideas to fix the problem?
  2. Dec 9, 2010 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Did you get it aligned?
  3. Dec 9, 2010 at 7:24 PM
    2004Taco
    Long Beach,CA
    Not yet but i didnt know getting aligned would help camber. i thought it just kept you driving straight.
  4. Dec 9, 2010 at 7:48 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    :smack:
    However, depending on how much your C/O's lifted the truck, you may not be able to return your camber to "in-spec" unless you have aftermarket UCA's.
  5. Dec 9, 2010 at 7:52 PM
    2004Taco
    Long Beach,CA
    And what is UCA's?
  6. Dec 9, 2010 at 7:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Upper Control Arms.
  7. Dec 10, 2010 at 5:16 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
