Positive camber on a new truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by m5allen, Dec 2, 2022.
  1. Dec 2, 2022 at 1:35 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I beg to differ. With bigger and especially wider tires you want more positive camber to offset the tendancy of the truck to tramline along with if you have less offset to the rims than stock you'll be moving the scrub radius of the tires further away from the intended zone causing more wandering. For toe I've found 0.02" to be okay but will be a little bit wander-y at highways speeds and 0.06" total toe to drive great but will start to wear the outter edges if you're not on top of your tire rotations
  2. Dec 2, 2022 at 1:55 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    My front hub to fender measurement dropped from 20.75+” new to 20.5” at 800 miles. So camber will come down quickly with it.
  3. Dec 2, 2022 at 3:17 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Had same issue. To the point where I could see the outer edges of the tires feathering within 5,000 miles. Brought it to Smithtown Toyota, where "they " aligned it. I rotated the tires and with 2500 miles same issue. Went to Guelphi alignment in Slip and the owner did it. First off I could see the difference right off the bat. Conditioned corrected. Submitted receipt to Smithtown Toyota , and they mailed me a check for a full refund.
    atc250r likes this.
  4. Dec 2, 2022 at 4:22 PM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Problem is the tech at the dealer is flat rate so "if it's in the green it's good".
  5. Dec 2, 2022 at 4:29 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Yep, mine does as well
  6. Dec 2, 2022 at 4:42 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I'm assuming IFS trucks come with a slight amount of positive camber so that it doesn't go too negative when the truck is carrying a payload, but I never really thought about it until just now. I lot of seemingly annoying aspects of trucks (e.g. rake, harsh ride quality) can be explained by thinking about a truck's primary purpose. It seems silly to me to modify the truck to get rid of them, unless you never carry a payload.
  7. Dec 2, 2022 at 4:49 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Have some one take a photo of a driver and passenger in the seats or all four seats filled
  8. Dec 16, 2022 at 4:22 PM
    ivan5105
    ivan5105 Member
    ivan
    San Juan, PR
    2016 Off Road Tacoma 4x4
    KDMax tuning,BP51,TRD intake and exh.,5.29
    I always use -.2 and no problems,also look better.
