Positive camber on stock OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BountyOR_VF2, May 30, 2017.
  1. Apr 29, 2020 at 6:09 PM
    #81
    andrewkissam
    andrewkissam Well-Known Member
    Dallas, Texas
    2017 Tacoma TRD Sport, DCSB, Silver Sky Metallic
    heritage grille, TRD beadlock wheels, TRD exhaust, TRD intake, rokblokz mudflaps, BFG KO2s 265/75r16, Toytec front spacer leveling kit, 2nd gen running boards, chin spoiler delete, MESO gasshole, Toyota bed mat, Toyota all weather floor mats, Tufskinz doorsill protectors, Diode Dynamics LED headlight conversion, LED reverse and plate lights, LED interior lights, Diode Dynamics 30" stealth light bar, TRD shift knob, TRD start button
    I've noticed visible positive camber on my truck since day one. I recently had my truck in at an independent alignment shop and they didn't have to adjust anything. They said everything was perfectly within factory spec and showed me the alignment sheet. I forgot what my numbers were now but I do know everything was in the green. I don't notice any outside edge tire wear either on my BFG KO2s with about 20,000 miles.
  2. Apr 29, 2020 at 6:17 PM
    #82
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Are you lifted?
  3. Apr 29, 2020 at 6:21 PM
    #83
    andrewkissam
    Dallas, Texas
    Only 1 inch and only in the front. I have a little 1/2 inch toytec top plate spacer which comes out to a 1 inch lift once installed.
  4. Apr 29, 2020 at 6:25 PM
    #84
    splitbolt
    NW Arkansas
    You remember what your caster was?
  5. Apr 29, 2020 at 6:26 PM
    #85
    andrewkissam
    Dallas, Texas
    No I don't, sorry. But like I said all my geometry was in the green. That I know for sure.
  6. Apr 30, 2020 at 7:39 AM
    #86
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    I talked with a local off road shop and they say outer wear isn’t necessarily from too much camber. Said it could be driving style and other alignment things. I’m getting new wheels with more offset soon so gonna have to get a new alignment anyways. Then I’ll know then how out of alignment I am/was. I haven’t gotten aligned in 10 months. I really think lifting makes positive camber worse or at least maybe you need to get it aligned more frequently because the suspension makes it go more positive faster than if stock maybe?
    71tattooguy likes this.
  7. Apr 30, 2020 at 7:40 AM
    #87
    ejewels
    CT
    I have duratracs, and the edges stick out more than KO2s I think, but either way I’m concerned about the wear.
  8. Apr 30, 2020 at 7:47 AM
    #88
    Sungod
    Sungod Well-Known Member
    St Augustine
    Optical illusion. You cannot eyeball an alignment. You can't see 1 degree. Outside wear comes from toe, not camber. Tires wear from friction and heat not from lean.
    Now you might see camber from parking lot binding. When you get and alignment your front tires sit on plates that allow the suspension to move freely as it is adjusted. This will also happen when you are driving.
    ejewels[QUOTED] likes this.
  9. Apr 30, 2020 at 7:49 AM
    #89
    ejewels
    CT
    So basically it can look out of alignment but it’s not?
  10. Apr 30, 2020 at 8:56 AM
    #90
    Sungod
    St Augustine
    Exactly. The idea is that when you are driving down the road the numbers go to zero. With toe, you want some positive toe static. Meaning that your wheels are pointed inward slightly. When being pushed, your wheels will open to zero. The opposite is true on front wheel drive. Because power is being delivered to them, they want to close up so you dial up a little negative toe to open them up.
  11. Apr 30, 2020 at 9:29 AM
    #91
    ejewels
    CT
    Any idea then on why I’d be getting more outer wear in my duratracs?
  12. Apr 30, 2020 at 10:01 AM
    #92
    splitbolt
    NW Arkansas
    Probably camber loss(added positive camber) and lateral load jacking due to change of steering geometry. It's wearing in turns...
  13. Apr 30, 2020 at 11:55 AM
    #93
    ejewels
    CT
    Wouldn’t everyone with a lift get this though? Maybe every truck is different.
  14. Apr 30, 2020 at 1:58 PM
    #94
    splitbolt
    NW Arkansas
    Or every one drives a little different.
    Do you do a lot of city driving with a lot of slow turning?
  15. Apr 30, 2020 at 2:32 PM
    #95
    ejewels
    CT
    Not really. Its possible my driving is the culprit though just on my normal routes. I'm getting new wheels/tires anyways so i'll keep a close eye once I get an alignment and ask the offroad shop to double check everything at the time.
  16. Apr 30, 2020 at 2:36 PM
    #96
    Sungod
    St Augustine
    Too much positive toe. That is what causes edgewear. Camber takes tens of thousands of miles to show up.
    ejewels[QUOTED] and splitbolt like this.
  17. Apr 30, 2020 at 2:52 PM
    #97
    splitbolt
    NW Arkansas
    Here are a couple videos that explain some of what's happening when you change steering geometry.
    Start @ 6:35
  18. Apr 30, 2020 at 3:32 PM
    #98
    ejewels
    CT
    Aka lifting a vehicle?
  19. Apr 30, 2020 at 4:38 PM
    #99
    splitbolt
    NW Arkansas
    More or less; there's a lot more to it.
    Although the videos don't address lift directly, the concepts are valid.
  20. Apr 30, 2020 at 4:42 PM
    #100
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    https://books.google.com/books/abou...JAC&printsec=frontcover&source=kp_read_button
    Everyone is right. The human mind has the capability of processing data that can be difficult to physically measure. Some people are better at this than others. The human mind can also be easily tricked as well. It all depends on the individual and thier capabilities of perception, and conversely thier biases.
    In my case both myself and my wife noticed positive camber on my 2018 at roughly 15k miles. Took it into the dealer and they verified that the camber was in spec, but the toe was out of spec. So go figure.
    ejewels likes this.
