Positive vs Negative Switching
Discussion in 'Lighting' started by Thelgord, Jul 3, 2016.
  1. Jul 3, 2016 at 8:57 AM
    Thelgord
    Thelgord [OP] The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    Are they any advantages/disadvantages when wring a switch for lights on the positive side or negative side of the light?
    Examples:
    POS ---> Light ---> switch ---> NEG
    Vs
    POS ---> switch ---> Light ---> NEG
    Any input would be appreciated.
  2. Jul 3, 2016 at 9:12 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  3. Jul 3, 2016 at 9:16 AM
    Thelgord
    Augusta, GA
  4. Jul 3, 2016 at 9:20 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    :thumbsup:No problem..That's why we're all here
    (err most of us)
    :quickdraw:
    Thelgord[OP] likes this.
  5. Jul 3, 2016 at 9:35 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    All of the OE lights and switches are negative switched and it will work just fine if you reuse the OE fog light wires for example for a set of aftermarket lights. If you are using the OE wiring you just have to be careful to order the correct switches if you swap out to aftermarket custom switches, just let the, know you need a negative switched switch. It will still work but the switch will not illuminate unless it is built for a net switch set up.
  6. Jul 3, 2016 at 9:41 AM
    Thelgord
    Augusta, GA
    I had no idea that OE was negative switched. Thanks for the info!
  7. Jul 5, 2016 at 3:45 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    A switch in DC (especially a single normally open switch) doesn't care whether it's in or out. Usually pinout on switches is for any LED indicators inside it. LEDs almost always have a resistor in front of them to step down the current going into the LED. A single position normally open switch doesn't care which side is power or ground in a DC circuit. To a switch it's either open or closed and nothing else.
  8. Jul 5, 2016 at 5:24 PM
    Thelgord
    Augusta, GA
    Yeah, I understand that part. I was just wondering if there is a "best practices" or prefered method.
  9. Jul 7, 2016 at 7:22 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    most older vehicles with a negative ground switch the positive side of the circuit because it's easy to connect the other side of the load to a metal grounding point anywhere on the vehicle.
    I guess the idea behind switching the negative is that if a wire were to fall off or some metal piece of the truck were to come into contact with the terminals on the switch, you wouldn't have a short circuit and blow a fuse.
    One reason Toyota switches the negative on the fog light circuit is they pick up the positive side for the relay coil from the low beam contact on the headlight relay. By doing this they allow the foglights to come on only when the low beams are on and not with the parking lights only or with the high beams.
  10. Jul 7, 2016 at 7:25 PM
    Large
    Large Red
    A good rule of thumb is negative switch whenever you can, less chance of sparks.
  11. Jul 8, 2016 at 4:27 AM
    Thelgord
    Augusta, GA
  12. Jul 11, 2016 at 1:52 PM
    digitaLbraVo
    Yeah I ran my hot leads to the positive side of the switch and my ground (relay/coil) to the negative lead. Most important rule is be consistent. Always wrong in a system that doesn't matter means it's always right unless you go mixy-wise for no reason.
  13. Jul 11, 2016 at 2:02 PM
    Clearwater Bill
    Billy
    Largo Florida
    Apparently somewhere along the way something changed. Maybe with the 15 models? Maybe only lighting?
    Anyway, I recalled reading about this recently, and had fortunately marked the thread I read it in. Maybe helpful in this situation?
    Read the 1st post in this super thread by @crashnburn80 and about 1/2 way down you'll find a testing procedure to determine what you have.
  14. Jul 11, 2016 at 2:10 PM
    digitaLbraVo
    I think the most important part is the OP knows the switch should not be driving the light, a relay should.
  15. Jul 11, 2016 at 2:23 PM
    Thelgord
    Augusta, GA
    Depends on the amount of power pulled. For a 500mW LED strip light not really needed. For a 100W Off Road Light, most definitely.
    digitaLbraVo[QUOTED] likes this.
  16. Jul 11, 2016 at 2:23 PM
    digitaLbraVo
    Great point actually.
  17. Jul 20, 2016 at 1:16 PM
    caribe makaira
    Caribbean, Puerto Rico
    It's the relay coil side that's "negatively" switched...
    Most switches used here in the forum that resemble OEM are of 20 to 30 amp capacity not needing a relay.
    I agree that having a large gauge wire and a high amp switch coming and going into the cab is very contrary to contemporary accepted method.
    Most folks here have overbuild harness's to actuate the .01 amp coil side and worst yet, a higher fuse than the actuated circuit requires negating the protection they seek. Example are the fog taps and other closely resembling modification/additions.
    Thelgord[QUOTED][OP] likes this.
