possibility of damage from rinsing truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by myn75, Mar 14, 2021.
  1. Mar 14, 2021 at 12:58 PM
    pescador95
    pescador95 Well-Known Member
    2017 white TRD sport
    This. Water gets into that gap anytime you drive over wet pavement. While the engine is hot, no less. I wouldn't sweat it.
  2. Mar 14, 2021 at 1:37 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    While driving in the rain, the engine is running and a little water splash is not an issue. The few drops that may enter the engine compartment usually evaporate right away on a continuously hot engine.
    However, when a large amount of cold water enters a hot engine compartment and onto a component, the thermal shock can cause a hairline fracture.
    The damage if any, usually occurs on the hot exhaust which may begin to be heard later and evidenced by a trace of black soot on the area of the fracture.
    To reiterate, no sense in worrying unless or until there evidence of any damage as this is not a common occurrence
  3. Mar 14, 2021 at 3:22 PM
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
    That is not true. It may be what people think but it is not true. I can tell you the engine testing by the manufacturer and their suppliers is far more rigorous that anything you can do with a water spray. Just the gasket manufacturers do thermal shock testing that takes a WOT engine down to idle and flush the block with room temp water. Rinse and repeat over and over. They do that for hours a day, multiple days in a row just for one set of gaskets. A few thousand hours of that on a block will eventually cause a failure. Sorry spraying water just won't do it.
  4. Mar 14, 2021 at 3:24 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    I take it you haven’t played in puddles. You should try it.
    The hammer likes this.
  5. Mar 14, 2021 at 3:27 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Lemon Law
    b_r_o likes this.
  6. Mar 14, 2021 at 3:28 PM
    myn75
    myn75 [OP] Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    Lol how fast thru it. Ive only gone thru 1.5ft ones at walking speed
  7. Mar 14, 2021 at 3:41 PM
    waltuo
    Toyotas
    Rubbish. I’ve seen minivans with more life than that.
  8. Mar 14, 2021 at 3:43 PM
    Bishop84
    Bishop84 Well-Known Member
    You should hear a truck drying off after full submerge
    TICK TICK TICK CLINK CLINK CLINK TOCK TOCK TOCK
    b_r_o, Rock Lobster, b3itz and 3 others like this.
  9. Mar 14, 2021 at 3:52 PM
    The hammer
    Rock Lobster and MaverickT883 like this.
  10. Mar 14, 2021 at 3:58 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I cracked the exhaust manifold on my 1st Gen (2.7) years ago by spraying water in that area.
  11. Mar 15, 2021 at 1:03 PM
    myn75
    Nor Cal
    any issues so far?
  12. Mar 15, 2021 at 1:04 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    You'll know
  13. Mar 15, 2021 at 1:07 PM
    myn75
    Nor Cal
    Interesting, wouldve figured the block to go first before the thinner parts on the exhaust manifold as i assume there would be more yield ability with the thinner steel metal, then again im just theorycrafting and im no engineer.
  14. Mar 15, 2021 at 1:09 PM
    GreyBaldTaco
    2019 F150 5.0
    We can tell
  15. Mar 17, 2021 at 4:34 AM
    #35
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    And me also.
  16. Mar 17, 2021 at 6:00 AM
    #36
    Tripod1404
    Tripod1404 Annihilator tripod
    I cracked two exhaust manifold screws on a jeep GC while trying to spray the wheel well. Not the manifold, but two of the screws that connect the manifold to the engine bock cracked. Likely due to unequal and rapid cooling/contraction of the manifold that stressed the screw. Manifold partially separated from the engine block and made a clicking noise when the engine was running.
  17. Mar 17, 2021 at 6:36 AM
    #37
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    And because Chrysler uses junk metal. I sold my 06 Grand yesterday before it disintegrated anymore than it already was.
  18. Mar 17, 2021 at 9:37 AM
    #38
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    Just to add fuel to this fire, I rinsed my engine off the other day. Garden hose sprayer set to ‘mist’. It worked well to rinse 11months of dust and dirt off. Engine was warm when I did it. No ill after-effects...yet!
  19. Mar 17, 2021 at 9:44 AM
    #39
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sorry OP! All in good fun!
    Bronxguy, BadDogMax, CSVT and 4 others like this.
  20. Mar 17, 2021 at 10:12 AM
    #40
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
