Possible 1st Gen clock fix...
Discussion in '1st Gen. Tacomas (1995-2004)' started by oldblue1968chevy, Mar 23, 2014.
  1. Mar 23, 2014 at 12:33 PM
    oldblue1968chevy
    oldblue1968chevy [OP] Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    May have to try this on my non operational clock...seems its a semi common problem...
    Posted for others Id searched a while before I found it ;)
  2. Mar 23, 2014 at 10:12 PM
    legbuh
    legbuh Active Member
    S. MN
    95 Taco SR5 4x4 3.4L
    Lift
    I'll try it soon. my clock is dead. I have a couple console bulbs to replace so I'll have it out anyway.
    If its just a conductivity problem I bet there would be even easier non-solder fixes that could be done.
  3. Jun 7, 2014 at 4:13 PM
    legbuh
    S. MN
    Lift
    Well, I tried it.. no go. My clock must have went to lcd heaven. :( But, I did get a light bulb replaced on the dash! I mended it!
  4. Jun 8, 2014 at 2:56 AM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    I've got one from my old taco. Green one. Yours if you pay shopping
  5. Jun 8, 2014 at 5:09 AM
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    There's a clock on the dash?
  6. Jun 9, 2014 at 5:59 AM
    legbuh
    S. MN
    Lift
    Thanks for the offer. I'm not really sure it's worth it. The picky side of me says do it, it's very inexpensive, but the frugal side of me says "you're not restoring this truck, it's a beater..."
  7. Jul 8, 2018 at 9:04 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    The hours won’t set on my clock. 00 and minutes work fine. Wonder if I can fix it the button? Anyone has the hours button not do anything?
  8. Jul 8, 2018 at 9:12 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Just wait till top of the hour and hit :00 button?
    cruiserguy likes this.
  9. Mar 12, 2020 at 12:27 PM
    rackomint
    rackomint Well-Known Member
    Anna TX
    2001 5-spd SR5 3.7L V6 4WD
    I resoldered the resistors like other have mentioned in the forums and it worked
    0xDEADBEEF, phx70 and cruiserguy like this.
  10. Mar 12, 2020 at 7:43 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You stud.
    So that's the pic of the resistor that goes bad then? Or the solder joints start to open up or something? Can you just add more solder on top of what's existing there?
  11. Mar 12, 2020 at 7:45 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Is that a before or after pic? That joint on the right doesn't look so great, needed more flux.
  12. Mar 12, 2020 at 7:47 PM
    rcmsr5
    rcmsr5 Well-Known Member
    Rodney
    Western N.C.
    04 SR5 4X4
    The clock on my gen1 works perfectly but I can’t see it because it’s hidden behind the steering wheel. Just another quirk I love about my truck.
    GQ7227 and cruiserguy like this.
  13. Mar 12, 2020 at 7:47 PM
    cruiserguy
    Elijah
    SEKS
    I found your other post with the pictures. That's what I was looking for, thanks for posting up pics dude:D:cool:
    rackomint[QUOTED] likes this.
  14. Mar 12, 2020 at 8:11 PM
    rackomint
    Anna TX
    That is the before picture. The reason the clock would not work was because of that crack in solder.
  15. Mar 12, 2020 at 8:12 PM
    rackomint
    Anna TX
    I found this video
    https://youtu.be/J-Z75rvHSSA
    cruiserguy[QUOTED] likes this.
  16. Mar 12, 2020 at 8:13 PM
    0xDEADBEEF
    Cool. 320 is about the size for a current limiting resistor on an LED, so that crack would definitely be an issue. Guess they were having some QC issues at the factory.
  17. Mar 12, 2020 at 8:15 PM
    rackomint
    Anna TX
    I have been reading up on it and there's a chance they used lead free solder and likely to crack over time with vibration. I resoldered all 3 of those resistors just in case. It's an (almost) 20y/o truck!
  18. Mar 12, 2020 at 8:18 PM
    cruiserguy
    Elijah
    SEKS
    Sweet man, that's something most of us can handle, thanks for the vid :D:cool:
  19. Mar 12, 2020 at 8:18 PM
    0xDEADBEEF
    Yeah, that could be it. Lead free has a history of being like that. Especially the older stuff.
    tacoma_ca and rackomint[QUOTED] like this.
