Possible 2012 Taco owner question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dpasc85, Feb 15, 2018.
  1. Feb 15, 2018 at 7:24 PM
    Dpasc85
    Dpasc85 [OP] Member
    Hello all I have driven cars mostly all my life and about 10 years ago I had a Mazda b3000 pickup and I loved it. Recently I made a small error in judgement and purchased a newer car and am looking to trade it in for a 2012 Tacoma. It’s a 2.7L 4cyl with about 82k miles. It is at a dealership and during test drive everything went fine and felt good but I noticed the check engine and TRAC light was on. I said something and was told no worries whatever the problem is it will be fixed before it is sold to you. What types of problems can this truck have and it’s current price is an even trade for my car at about 15,000 from NY. Any input appreciated I am just looking to do a little 4x4 on the beach once in a while ..possible light towing like a pop up camper or something and everyday driver. Thank you
  2. Feb 15, 2018 at 9:08 PM
    Pigpen
    Dan
    Northwest Montana
    It's the dreaded secondary air injection failure. It recently became something Toyota will cover. It used to cost over $2000.
    The valves must be stuck open. If they were closed, it would be in limp mode.
  3. Feb 15, 2018 at 9:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I know this is an issue with the 4.0 V6 but I have not heard of any horror stories about the 2.7 liter 4 cylinder. I would get them to show me the codes and prove it was fixed first.
    Sterling_vH111 likes this.
  4. Feb 16, 2018 at 5:31 AM
    Dpasc85
    Dpasc85 [OP] Member
    Ok I will look into them giving me the codes and look them up or have my mechanic check them out . Also offhand is the truck a good solid truck I have seen some of these Tacoma’s with 200k miles which is great . The second owner of this vehicle put around 23k miles per year. As long as toyoyta will cover that big issue I’m ok with it if it happens again
  5. Feb 16, 2018 at 6:17 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Think long and hard if you want a 4 cylinder truck.
  6. Feb 16, 2018 at 6:30 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    If you do buy it..........make sure you get two master keys !
    Its a real PIA to get one made......especially if you in rural America........
    dealer will charge $175-200 ? not sure....I finally got a spare...locksmith....
    $12 for blank.....$54 to program
  7. Feb 16, 2018 at 10:17 AM
    Dpasc85
    Dpasc85 [OP] Member
    Why is that? Personal opinion or something I should know . I had a v6 truck and it ate gas and if I can tow the small things I need and use the 4x4 on the beach while getting decent gas mileage than I don’t see an issue personally. I am more concerned overall the performance of the truck itself and reliability
  8. Feb 16, 2018 at 10:22 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    One its possible it was just the gas cap that was loose. i4 trucks have had the air injection on them and havnt had the issues nearly as much.
    i4 is a solid motor but its not gonna be making much for power so just keep that in mind.
  9. Feb 16, 2018 at 10:25 AM
    TacomaMike37
    13' DCLB MGM
    Just offering my real world experience nancy.
    I've read threads on here where owners regret buying a 4 cylinder cause its a dog and MPG can be pretty damn close to the V6, then they have to go through the process of taking a financial hit to get into a V6. Seems like you already made one mistake automotive wise , so why make another?
    To each his own, do what fits you!
  10. Feb 16, 2018 at 10:35 AM
    Dpasc85
    Dpasc85 [OP] Member
    I hear ya so you are offering personal opinion and I thank you for input. It’s all relative ..I’ll show you posts of people with v6 who wish they had just gotten a v4 too I’m sure. It depends what you want to use it for. Mine would be daily driver and minimal towing and I could be wrong but online said 12-18 on v6 and 18-27 on v4 . Unsure if that was manual tho if that makes a big difference . I am asking broad questions about the motor and life of the vehicle.
  11. Feb 16, 2018 at 10:39 AM
    FourBanger99
    FourBanger99 4 Banger Taco
    Bayne
    Birmingham
    2012 Black Tacoma 2.7 AC SR5 4x4
    Full OME Suspension CB Diff Breather Duratracs
    I have a 2012 aclb 2.7 and it has been pretty much bullet proof. Cast iron block and simpler internal mechanics will always be more reliable compared to the 4.0. I regularly wheel mine and in the 3 years I’ve owned it it’s seen the redline a whole lot in mud holes and on the street. I change the oil like religion and this engine has never had a single issue. The only thing I’ve had to replace was my serpentine belt because it got gunked up with mud and sand. If you take a look in my air box you’ll see that there has been mud and water that got past the air filter yet it just chugs along. I thrash the hell out of this motor and way more than I should and it just works.
    https://www.instagram.com/p/BZ6juM6nB-2/
  12. Feb 16, 2018 at 10:42 AM
    Dpasc85
    Dpasc85 [OP] Member
    Appreciate the input thank you! Other than getting that light checked out it looks and runs nice. I’ll keep you posted on what I decide . Thank you again
  13. Feb 16, 2018 at 10:43 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Really the only issues with the 2012+ trucks are the air pump, just make sure that gets fixed on the dealers dime, and the i4’s are super solid, just pretty weak. But if you don’t need / want the power of the v6, save some bucks and get the 4cyl!
    Also probably unlikely due to the newish year of the truck, but it never hurts to do a quick undercarriage check on the frame and other suspension parts for rust depending on where you live.
  14. Feb 16, 2018 at 10:50 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Welcome to TW- Hope the deal works out for you& be sure to check the under carriage/frame if the truck came from "Salt" country
    FourBanger99 likes this.
  15. Feb 16, 2018 at 12:24 PM
    Dpasc85
    Dpasc85 [OP] Member
    The truck has been in Long Island NY for all it’s use
  16. Feb 16, 2018 at 12:30 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Or it could be a bad or loose gas cap.My 2015 had the same problem and it was a loose gas cap.
  17. Feb 16, 2018 at 12:33 PM
    lynlan1819
    Tacoma
    Lifted
    Nothing at all wrong a i4,very very reliable.
  18. Feb 16, 2018 at 12:47 PM
    nd4spdbh
    SoCal
    as stated i4 trucks have had the air pump since day one. only 2012+ v6s got it.
  19. Feb 16, 2018 at 12:59 PM
    Dpasc85
    Dpasc85 [OP] Member
    Thank you all for info on the truck I will keep posted on what the codes were
  20. Feb 17, 2018 at 4:59 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The 4 bangers ( 2.7 liter engine ) do not have the engine immobilizer system. ( No chipped key ). Just regular keys you can have made anywhere for a couple of bucks.
