Possible bad bearing and torn boot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DKY42, Nov 6, 2016.
  1. Nov 6, 2016 at 1:03 PM
    DKY42
    DKY42 [OP] Well-Known Member
    Ohio
    2013 4X4 TRD Sport
    Just recently started noticing grumbling noise on front end when I get up to 40 or 50 mph. Does this for sure sound like a bad bearing, and if so how do I know what side? I jacked up and spun wheels but I don't hear anything significant.
    Also just noticed I have a torn boot, CV I assume. How hard is this to change and does anything need disassembled. See picture.
    Preview attachment IMG_1457.JPGIMG_1457.JPG424 KB
    Thanks!
  2. Nov 6, 2016 at 1:11 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I got bearing from one of the guys on TW and put it in in 2 HRs - the second one in 1:20 so if you have tools and know how to use them it's easy - don't have a split boot so don't know about that. I had a split boot on something else and got a kit with a boot that was in 2 parts - you put on with hose clamps and glue - worked fine - didn't have to remove anything.
    DKY42[OP] likes this.
  3. Nov 6, 2016 at 1:14 PM
    DKY42
    Ohio
    2013 4X4 TRD Sport
    Thanks for the tips! How did you know your bearing was bad? Good to know on boot cover. Trying to figure out if the slip over/glue together will hold up like a complete boot.
