Possible blown head gasket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EDJY, Jul 12, 2014.
  1. Jul 12, 2014 at 10:13 AM
    EDJY
    EDJY [OP] Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Hello fellow tacomaworlders,
    I am trying to figure out if I damaged my head gasket in a freak overheating incident. It overheated as I pulled into a gas station while towing a trailer. It happened way to fast to initially prevent. Literally everything was normal (around 200 on the scanguage) then my needle went strait to red line. Do not pass go, do not collect 200 dollars. I mean within 4 seconds. Now 250 on the scan gauge.
    Since it was already fully overheating I tried revving it up to try to get more air through the radiator. This worked amazingly well actually and temps immediately started dropping. Turns out that the thermostat got stuck closed, or partially closed and the higher rpm pushed more water through my engine so, it had less to do with the fan.
    After this whole ordeal and one thermostat later, I was keeping an eye on my coolant levels and noticed that there is always a constant stream of bubbled getting pushed out the reservoir that increases as you rev the engine up.
    Is this normal???
    I Never really payed attention to my coolant reservoir before while the truck was running. Also never looked at how much moisture was getting pushed out the exhaust, but now it looks significant. I may just be a little overly concerned.
    My coolant levels do not really seem like they are going down and the coolant doesn't seem dirty yet, but time will tell. I am just really curious about these damn bubbles.
  2. Jul 12, 2014 at 10:37 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    If the level remains full and there is no coolant smell don't worry about it.
  3. Jul 12, 2014 at 10:53 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Change your oil and send a sample in for a UOA. They'll be able to tell you if there is coolent in it.
  4. Jul 12, 2014 at 11:03 AM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Easy way to tell if you have a Head Gasket Issue is. Take the truck for a drive and get it up to normal running temp. When you get back to the house pop the hood and see if there if it is boiling in the overflow bottle. Also check and see if you have white crusty residue around the overflow bottle, that is antifreeze being boiled out while you are driving the truck. This is what my 2005 did when my head gasket was blown and if you do a search on GOOGLE it will tell you the same thing,
    Benny123 and foampile like this.
  5. Jun 1, 2015 at 4:18 PM
    foampile
    foampile Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    what is UOA ? i would like to perform this check on my truck
  6. Jun 1, 2015 at 4:23 PM
    foampile
    Mid-Atlantic
    isn't another symptom also frothiness around the oil dipstick, indicating that coolant has penetrated into the oil ? what if i am getting boiling bubbles in the overflow tank but there is no whitish residue or frothiness on the oil dipstick ?
  7. Jun 1, 2015 at 4:26 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Used Oil Analysis
    foampile[QUOTED] likes this.
  8. Jun 1, 2015 at 4:29 PM
    foampile
    Mid-Atlantic
    thanks. do you know if there are well known service providers that do this via mail or should i see a local shop ?
  9. Jun 1, 2015 at 4:39 PM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
  10. Jun 1, 2015 at 5:13 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    I use Blackstone Labs. Unlike other labs, they send the kit for free, and you pay for analysis when you send your oil sample in. Other labs charge you upfront for the kit.
  11. Jun 1, 2015 at 8:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Zombies!!!!! from 2014.
  12. Jun 1, 2015 at 8:38 PM
    mpm
    mpm Well-Known Member
    If you absolutely MUST have the piece of mind of having your oil analyzed, go for it. But in all the situations in which I had a failed head gasket on non-toyota engines, I had overheating issues, as well as an eventual milkshake appearance of the oil. My coolant levels were also slowly dropping. The issue with failed head gaskets is that oil and coolant paths are no longer separate, and since both are pressurized systems, on top of the pressure of combustion occurring inside the cylinder, the 3 separate systems are mingling in a very unnecessary manner. I would monitor your temps, check your coolant levels, and look for the oil to become milky. If you aren't seeing any changes in those 3 areas, you are probably okay.
  13. Jun 9, 2015 at 6:59 PM
    TRDMastaTech
    TRDMastaTech Member
    David
    Carmel, CA
    07 TRD Yota
    How about rip into it and do a head job for fun. Only takes 20 hours. Not including sending the heads out for machining. :itllbuffout:
  14. Jun 9, 2015 at 7:27 PM
    TRDMastaTech
    TRDMastaTech Member
    David
    Carmel, CA
    07 TRD Yota
    If peeing your pants is cool, consider me Miles Davis.
    Benny123 likes this.
  15. Jun 9, 2015 at 7:53 PM
    foampile
    Mid-Atlantic
    Also consider using a combustion leak detector kit (AKA block tester) to chemically test the fumes out of your radiator for an indication of blown head gaskets. i got the one from the last link and it worked well (tested negative) but the poor UX is that it requires a separate suction pump which needs to be adapted to its hose so i definitely recommend spending a few extra $$ and getting this one, which comes with a small pump.
    I am not sure how that test compares with UOA.
    Good luck
