Possible discount for The Retrofit Source
Discussion in 'Lighting' started by CopDoctor, Feb 25, 2010.
  1. Mar 5, 2010 at 9:44 AM
    #121
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    ^ I can't wait and I'm going to take my time on this. I bought a Set of Like New OEM Headlights that I'm going to start FRESH!
    $325 For the TRS Kit
    $100 For Excellent OEM Headlights
    $20 OEM Sealant
    Total = $445 & Time
    I will be selling my Excellent BHLM w/Yellow Accent for $150
    Rad Red T-Rex Eyelids for $40-$50
    So I can deduct $190-$200 off that Total. Not Bad ! ! !
    I'm going all the way with this!
    PEOPLE GET ON THIS NOW ! ! !
    This is the BEST price you can possibly get for the RETROS.
    If you're in Socal. We are going to plan a RETRO Fit Day for the guys who got the kit. How many in Socal?
  2. Mar 5, 2010 at 9:50 AM
    #122
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    seriously guys....$325 W/ phillips bulbs is an excellent price!!
  3. Mar 5, 2010 at 9:51 AM
    #123
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    One in socal here but I will not be free until the 22nd... :S I'll be in on a business trip in FL then a trade show in ontario right after that.
  4. Mar 5, 2010 at 12:52 PM
    #124
    RDAY
    RDAY Well-Known Member
    NY
    07 Tacoma SR5 4x4
    where did u get the oem sealant is it necessary to buy extra sealant or will it seal fine with just putting it back together and heating it up any tips as far as making sure it doesnt fog up?
  5. Mar 5, 2010 at 1:00 PM
    #125
    yosh2000
    CO
    '17 Tundra CM 5.7
    i've done several headlights just reusing the sealant...as long as you let warm up in a 300 preheated oven (but TURNED OFF!!!) for 10 min, there is no reason the OEM sealant needs to be replaced.
  6. Mar 5, 2010 at 1:48 PM
    #126
    RAD
    Rad
    LAX & LOGAN
    ^ I got more OEM Sealant because I don't want to ever open these bad boys up again. Better safe than sorry. I'd like to do it right the first time.
    You don't need to get it but I personally will.
    I'm not going to cut corners on this and I'll take my time with it.
  7. Mar 5, 2010 at 2:33 PM
    #127
    RDAY
    NY
    07 Tacoma SR5 4x4
    where did u get it?
  8. Mar 5, 2010 at 2:33 PM
    #128
    joshua32
    joshua32 Well-Known Member
    Joshua
    Tyler, TX
    06 Prerunner SR5
    Where did you get the stuff from, the dealership or online? I think I might end up doing the same as I don't want to have to do this twice due to the headlights leaking.
  9. Mar 5, 2010 at 2:49 PM
    #129
    yosh2000
    CO
    '17 Tundra CM 5.7
    3m windshield sealant is what a lot of guys use on HIDplanet
  10. Mar 5, 2010 at 2:52 PM
    #130
    yosh2000
    CO
    '17 Tundra CM 5.7
    but you've opened up tons of headlights now right...did you do this w/ them as well? your pro!
  11. Mar 5, 2010 at 4:25 PM
    #131
    RAD
    Rad
    LAX & LOGAN
    Yes, I've ton a ton and used the 3M window sealant or GE Silicon II. Both work amazing.
    However, I'm going all out on this and spending a lot. I'm goign to splurge and make it look OEM with extra OEM Sealant. I got it from the Nissan Dealership. toyota doesn't sell it.
  12. Mar 5, 2010 at 4:33 PM
    #132
    yosh2000
    CO
    '17 Tundra CM 5.7
    ...until you change your mind and redo them...a few weeks later...someone quote me so this statement is permanent!!
  13. Mar 5, 2010 at 6:31 PM
    #133
    RDAY
    NY
    07 Tacoma SR5 4x4
    does anyone have a link to the 3m stuff where do u get it?
  14. Mar 5, 2010 at 8:57 PM
    #134
    yosh2000
    CO
    '17 Tundra CM 5.7
    here is a link to the stuff....:D
    you can also ask ray where he got his nissan stuff for $20, as that is what guys use as well on HIDplanet.com
  15. Mar 5, 2010 at 9:01 PM
    #135
    CopDoctor
    CopDoctor [OP] Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    i heard aquarium stuff is good to use..i just used the stuff over again, no problems here, not like you lose any goop or anything, still the same amount. plus you don't want to make it bomb proof, chances are you'll need to open them again to fix a mistake/add/remove something
  16. Mar 5, 2010 at 9:23 PM
    #136
    RAD
    Rad
    LAX & LOGAN
    ^ Once I'm ready to close them. I don't plan to open them. The reason why I got more Sealant was when you remove it. It moves around from the original location and its not the same. So I use more in certain locations. Its not like I'm over doing it.
    I got the part # from the Nissan site and went into my local Nissan Dealership and ordered. Came out to like around $23. I used some of it and still have some left. I will keep it for future BHLM.
    Here is the link
    http://www.mynismo.com/products/?id=5577&rsku=0
  17. Mar 5, 2010 at 11:11 PM
    #137
    raskal311
    S. Cal
    Thats just silicon....
  18. Mar 6, 2010 at 10:51 AM
    #138
    yosh2000
    CO
    '17 Tundra CM 5.7
    that stuff looks just like the 3m stuff i got off egay for $7 shipped. that stuff doesnt harden does it? the 3m stuff stays pliable.​
  19. Mar 6, 2010 at 6:47 PM
    #139
    raskal311
    S. Cal
    So how many more to go?
  20. Mar 7, 2010 at 6:52 AM
    #140
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    I would like to get in on this deal if it is not to late. I can order first thing in the morning if it helps.
