Possible Driveline Shudder/Vibration Fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flatus, Aug 19, 2016.
  1. Dec 22, 2016 at 4:29 PM
    #181
    Contra472
    Contra472 Well-Known Member
    2016 Tacoma DCSB 4X4 OR
    I see you have an Off-Road. Did you get your truck fixed through the new TSB?
    Thanks
  2. Dec 23, 2016 at 1:47 PM
    #182
    neegra
    neegra Well-Known Member
    GA
    2016 DCSBTRDOR4x4
    Yes. T-SB-0171-16 per the paperwork
    PNs were:
    48210-04840 Spring Assy, RR RH
    48220-04480 Spring Assy, RR LH
  3. Nov 20, 2017 at 12:22 PM
    #183
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    mine has this vibration that just started about 6 months ago,feels like you are on a rub board road at 50-55 .....speed up or slow down and it stops...so is there any fix??
  4. Nov 20, 2017 at 1:07 PM
    #184
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    Just got the TSB leafs, dampner and alignment. I can say I am now vibe free. Hahaha!
  5. Nov 20, 2017 at 1:16 PM
    #185
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    what you describe is different than what this post is about. vibrations at 50-55 only are probably tire balance related.
  6. Nov 20, 2017 at 2:35 PM
    #186
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    well..if you let off the throttle a little it stops to...but it only does it 50-55..ujoints are good..wondering if its the torque convertor doing it.
