Possible Electrical Short?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1wildmonkey, Jul 1, 2017.
  1. Jul 3, 2017 at 7:53 PM
    #41
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    See attached pdf. for other fuses. Are the fuses all good? Or does it still blow the gauge fuse.
  2. Jul 4, 2017 at 9:30 AM
    #42
    Taziknez
    Taziknez New Member
    Paul
    2001 dodge ram extended cab 4x4
    So I'm the friend whose been assisting in the fun. Grounds were checked with an ohm meter from the negative post to various points under the hood, on the engine, and under the dash. Couldn't get anything but zero ohms anywhere including moving various wires. When we put everything back together and started it cause I wanted to see it die, immediately after it died, battery dropped to 9v and came back up to 11 within seconds, I immediately unbolted the positive cable and hooked up a test light inline, and only a faint glow from the radio memory. So faint only visible in the shade if you cupped your hand around the light. Supposedly the shop that "tested" the battery charged it, and after 20 minutes of the engine dying was still only at 11.9v which is completely dead. But no current draw inline which makes me think it's not a short just a bad battery. It was six years old and we live in a desert. New battery was 12.65 until engine started 12.4v had 12.4 at the alternator, but Napa tested the alternator . So I'm curious as to the three wire connector at the alt. One wire goes to the gauge, one is for sensing voltage, and the other is for? I'm familiar with older Toyota's and various makes and models but don't have a good wiring diagram in front of me. Could the alternator be not getting any voltage for the three wire to energize it? That would explain it not working in the truck but functioning when on the test bench at napa? Can anyone explain what the three wires go to, and what voltage should be there with key on engine off and key on engine on?
  3. Jul 4, 2017 at 9:37 AM
    #43
    mechanicjon
    Jon
    Scottsdale Arizona
    Key on engine off 2 of the smaller wires should have power, red and white and of course the big wire will have power. The yellow wire controls the dash light and signals the DRL's the engine is running by sending power to it. The smaller red wire is the signal wire for the alternator regulator to turn on. Small white wire is the voltage sensing wire.
  4. Jul 4, 2017 at 9:38 AM
    #44
    mechanicjon
    Jon
    Scottsdale Arizona
    If you got 6 years in the desert out of a battery you're doing better then most
  5. Jul 4, 2017 at 9:39 AM
    #45
    mechanicjon
    Jon
    Scottsdale Arizona
    I posted a wiring diagram in the attached pdf above.
  6. Jul 4, 2017 at 9:50 AM
    #46
    Taziknez
    Taziknez New Member
    Paul
    OK so looking at that, the red wire is tied into a 10a fuse. Is that the gauge fuse?
  7. Jul 4, 2017 at 9:59 AM
    #47
    mechanicjon
    Jon
    Scottsdale Arizona
    yes
  8. Jul 4, 2017 at 10:01 AM
    #48
    mechanicjon
    Jon
    Scottsdale Arizona
    Have you ever determined what causes the gauge fuse to blow?
  9. Jul 4, 2017 at 10:03 AM
    #49
    Taziknez
    Taziknez New Member
    Paul
    Which would be the fuse that keeps blowing.. I'm 20 minutes away from the taco right now. Need to finish moving into my new place today and clean my condo, but hopefully monkey will check those wires and report back his findings.
    mechanicjon likes this.
  10. Jul 4, 2017 at 11:22 AM
    #50
    1wildmonkey
    1wildmonkey [OP] Member
    03 Tacoma, 2.7 L, manual trans
    I'm hoping that tbe dead battery was the cause of the dash fuse to blow. Haven't run the motor much at all to determine if that problem really is fixed or not. All other fuses look good. As far as the alt wires, white is reading 12.47, red is at 12.34, and yellow is actually at 12.15.
  11. Jul 4, 2017 at 11:24 AM
    #51
    1wildmonkey
    And I dont know what just happened, but all of a sudden I'm getting 14.3 v at the alt. I'll keep this running for a bit to see if its okay now..
  12. Jul 4, 2017 at 11:40 AM
    #52
    1wildmonkey
    Its been running for 10 min now with a.c., radio, lights all on to create as much draw as possible. Reading around 14 v still with everything? I'm not really a fan of things fixing themselves when I haven't done anything...could it have been a bad connection somewhere that I just fixed when doing all these tests? I will keep an eye on everything but it always worries me when the problem just disappears.
  13. Jul 4, 2017 at 12:45 PM
    #53
    mechanicjon
    Jon
    Scottsdale Arizona
    Try wiggling the wire harness for alternator while its running. See if the voltage fluctuates at while doing that.
