possible elocker problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by luke8603, Jul 25, 2010.
  1. Jul 25, 2010 at 9:31 PM
    luke8603
    luke8603 [OP] Member
    luke
    cape cod
    01 trd taco
    ome 881s, 2" AAL, All pro UCAs, deckplate, grey wire
    hopefully im not the only one with this problem... from time to time my locker indicator light along with the abs light will mysteriouly come on without hitting the switch. the locker dosent actually engage but the abs definately dosent work when this happens. the locker itself seems to work flawless. anyone got any ideas
    truck is a 2001 ex cab taco 3.4
  2. Jul 25, 2010 at 9:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Jul 26, 2010 at 5:01 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    There is a switch on top of the rear axle that Toyota refers to as a "Diff. lock indicator switch". I had the same symptoms twice now and replacing this switch solved the problem (on my 2005). Switches are known for shorting out from time to time, fooling the ECU into thinking the e locker is engaged, therefore disengaging the ABS.
  4. Jul 26, 2010 at 8:04 PM
    luke8603
    luke
    cape cod
    01 trd taco
    yep 4x4
