Possible exhaust leak or just TRD exhaust ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BAD430BENZ, Apr 2, 2015.
  1. Apr 2, 2015 at 8:52 AM
    BAD430BENZ
    BAD430BENZ [OP] Well-Known Member
    EL PASO , TX
    Supercharged TRD PRO
    Like the title says , my exhaust when under load , sounds like it might have a possible exhaust leak . I didn't know if that was just the standard sound or if mine might be a little loose at some point in the exhaust .
  2. Apr 2, 2015 at 8:56 AM
    Aw9d
    Aw9d That one guy
    I just kneel down by the truck and have someone rev the exhaust. If there is a leak you'll hear it.
  3. Apr 2, 2015 at 9:11 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    If the sound has significantly changed since you installed the TRD, it might be a leak
  4. Apr 2, 2015 at 9:54 AM
    BAD430BENZ
    EL PASO , TX
    I know....that's my plan
    I have the PRO so the exhaust is standard . I'm hoping that someone else with a supercharged PRO can chime in if they have had the same thing happen since supercharged .
  5. Apr 2, 2015 at 10:05 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    So this happened when you added the supercharger?
  6. Apr 2, 2015 at 10:07 AM
    BAD430BENZ
    EL PASO , TX
    the supercharger was added before I even picked up the truck :D
  7. Apr 2, 2015 at 10:10 AM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Not sure what exactly you have but mine is beginning to leak at the joint near/under the passenger seat at the flange. Mine is noticeable going up a hill and at 1000-1200 rpm.
  8. Apr 2, 2015 at 10:35 AM
    BAD430BENZ
    EL PASO , TX
    Mine is the TRD PRO but that is pretty damn close to what is happening with mine . My truck only has about 1500 miles on it so I would hope the exhaust would last longer than that :D
    Might just be an installment issue from the factory . Time to hit the dealer for a little inspection .
  9. Apr 2, 2015 at 10:38 AM
    Mr Ribby
    Mr Ribby Well-Known Member
    Andrew
    NW Indiana
    2013 "Baja"
    Pioneer DvD double din, pioneer 5way front door speakers, kicker 3 way rear door speaker
    I'm not sure what a leak sounds like, but mine makes some odd noises as well sometimes (but im not supercharged) =(
  10. Apr 2, 2015 at 11:01 AM
    BAD430BENZ
    EL PASO , TX
    it's basically similar to an air leak , which i'm sure you know what that sounds like .
  11. Apr 2, 2015 at 12:58 PM
    jhuggans
    jhuggans Member
    Warrensburg, MO
    2010 ACL 4x4 2.7
    I feel like my 2015 DCLB Sport has leaked since day one (no s/c or trd exhaust). It's faint, and it almost just sounds like engine noise but to me it's leaking. I'm at about 5000 miles and I haven't got underneath to diagnose any more.
