Possible exhaust leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MACKT28, Feb 21, 2025.
  1. Feb 21, 2025 at 2:19 PM
    MACKT28
    MACKT28 [OP] Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Noticed some weeping coming from my exhaust before the exhaust flange where the two bolts connect and also noticed there was some black soot looking stuff where the weeping is coming from is that normal or do I need to get an exhaust shop to weld up the hole?
  2. Feb 21, 2025 at 2:26 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    It could just be in need of a new gasket. Post a pic of the joint you are referring to.
  3. Feb 21, 2025 at 2:43 PM
    MGMDesertTaco
    Sounds like a blown out gasket.
  4. Feb 21, 2025 at 3:51 PM
    MACKT28
    2006DCLB
    It's weeping out before the flange not at the flange where the bend is before getting to where the gasket is. Should I still have that gasket replaced?
  5. Feb 21, 2025 at 4:15 PM
    JAGCanada
    Canada
    A picture would be really helpful
    zguy1 likes this.
  6. Feb 21, 2025 at 4:42 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    picture or your given advice is bad.....
