Possible knocking sound, goes away with 91 octane
Discussion in '1st Gen. Tacomas (1995-2004)' started by whizfish, Aug 18, 2022.
  1. Aug 18, 2022 at 10:41 AM
    whizfish
    whizfish [OP] Well-Known Member
    '01 Xtracab 4x4 V6 Manual TRD SR5
    Stock
    My '01 6cyl 4wd manual with 238k on it has developed a knocking sound when attempting to accelerate or climb at lower RPMs (1800-2100rpm or so). It started relatively recently (since June) and when I put a tank of 91 octane in it (normally use 87 or 88) the noise is gone. I drove it across the country in May after giving my mechanic more or less free reign to find and fix whatever he found was needed (radiator, clutch, valve cover gasket, some bushings, et al) but he didn't find or fix anything directly related to how it runs. The only OBD code I'm seeing (occasionally) is something about the evap sensor/purge but that's been an on again off again issue for a couple years now.
    Any ideas? Home is in California but I'm in rural Maine at least through October and haven't yet developed a relationship with a mechanic out here. I guess I'd just like to have some ideas in mind before I go looking for one.
    Thanks,
    Dan
  2. Aug 18, 2022 at 11:01 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Do you have an OBDII reader like a scangauge or an ultragauge? Check your fuel trims. Those will give you an indication of a problem. When was the MAF last cleaned?
  3. Aug 18, 2022 at 1:44 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    I’ve been watching this guy for a couple years. Wish he lived near me. South main auto LLC.
    https://g.co/kgs/NjaiZK
  4. Aug 18, 2022 at 2:03 PM
    alexh
    alexh Well-Known Member
    1998 TRD
    I noticed faint knocking on my 3.4 at about 200k miles, switched to premium. However, I had a weak fuel injector for quite a while and I don't remember if the repair was before that - I think it was. Perhaps I'll try 87 to see if it still knocks but I think many people here are running premium because engine seems to run better and some say better mileage also. Why an engine with only 9.6:1 compression ratio runs better on premium is beyond me but seems to be the case.
  5. Aug 18, 2022 at 7:42 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    You might have a cylinder or two that are running lean. A low flowing injector could cause that. Carbon buildup on the pistons would also be a culprit.
