Possible leak ???
Discussion in 'Technical Chat' started by EGtaco, Jan 14, 2010.
  1. Jan 14, 2010 at 2:09 PM
    EGtaco
    EGtaco [OP] Well-Known Member
    2009 Tacoma
    You know how when you run your AC during the summer and you park there is always some water "leaking" from the compessor. Well I have always noticed this "leak" every time i drive my truck (2009 / 4wd) when I park it. It is coming from the passenger side someplace between the engin and the front seat. Yeah I know that is a vauge discription but is it normal? Is is just a part of the cooling system letting off some steam?? It happens when it is hot, warm, cold, and freezing.
    Does everyones truck do this???
  2. Jan 14, 2010 at 2:12 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    It's normal. All A/C systems have a drain tube that leaks water. So you use your A/C when it's freezing ?
  3. Jan 14, 2010 at 2:37 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ide say its not normal.mine doesnt do it.ONLY when the ac is on.
  4. Jan 14, 2010 at 2:40 PM
    Asgard
    Sorry I must have misunderstood the OP, it should only leak if you're using the A/C.
  5. Jan 14, 2010 at 2:41 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...Leaking while the AC is on makes sense- The AC uses a CONDENSER which means some water will drip out. If it does it all the time...some thing is wrong (Unless you run the AC all the time)
  6. Jan 14, 2010 at 2:41 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    no problem,i thought i was crazy or something.well........maybe to some degree i am.lol.
  7. Jan 14, 2010 at 3:10 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    ac comes on when you run defrost it doesn't indicate though
  8. Jan 14, 2010 at 3:15 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Can you determine what the fluid is? Stick your finger in it and smell it.
    If it doesn't smell like anything - and it could just be water.
    The only other thing I'm thinking it could be, is radiator fluid. That'll be pink, be somewhat slippery in your fingers....
  9. Jan 14, 2010 at 3:24 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    It's water caused by condensation. The accumulator is cold, the air around it is warm, therefore condensation forms and it drips on the ground. Nothing to worry about unless the fluid is something other than water.
  10. Jan 14, 2010 at 3:29 PM
    Janster
    Jandy
    Lancaster, PA
    I understand that...
    But does the OP know for sure that its water?
    That was my point. To make sure the OP knows for sure its water and not something else.
  11. Jan 14, 2010 at 3:34 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Sorry Janster, I meant to quote the op. I think I need more sleep:D. You are right, he needs to make sure it's water first and foremost.
  12. Jan 14, 2010 at 4:21 PM
    EGtaco
    2009 Tacoma
    Thanks guys....
    it is clear liquid (water like) and I typically do run the defrost most of the time on low to keep the windows clear and warm up a little. Not using the AC right now. There is a drip 100% of the time when I park my car after driving for 5 minutes or more. All my fluid levels are fine so I figured it was condensation from the comperessor or something but I get it even when no AC is used??????.
  13. Jan 14, 2010 at 4:28 PM
    EGtaco
    2009 Tacoma
    maybe these pics will help. I was driving around for 20 mins and the truck has been parked for maybe 10mins. I did not taste the liquid but it is clear and feels like water.
    It is coming from an area under the frame and I cant see it...the dark line is the water dripping down the frame
  14. Jan 14, 2010 at 5:31 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    that frame pic looks alittle far back to b from the ac line.mine drips down(when ac is in use)from the rear of the pass. side fender well.maybe they re routed the line further back on the newer ones???
  15. Jan 14, 2010 at 5:45 PM
    Asgard
    ^^Mine drips and runs along the frame similar to the OP's.
  16. Jan 14, 2010 at 5:50 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Running the defroster does engage the A/C system to lower humidity which will cause condensation.
    I'd recommend extending you AC drain line to keep water off your frame but other than that it looks normal.
  17. Jan 14, 2010 at 7:37 PM
    Janster
    Jandy
    Lancaster, PA
    No worries...it's the internet. And if you catch people in the right mood - well, you know. I'm a bit crabby being on this shift (2nd).:mad: My apologies if it sounded harsh
  18. Jan 14, 2010 at 8:32 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Not harsh at all.:)
