Possible Meetup/ Need Help - Tuscon
Discussion in 'Arizona' started by infantry, Mar 27, 2013.
  1. Mar 27, 2013 at 8:14 AM
    infantry
    infantry [OP] Member
    07 PreRunner Ext Clean
    Hello,
    I am new to AZ and will be in Tuscon this weekend to pick up a bike.
    I was hoping someone with some electrical knowledge could help me out. (Ill throw you a 6 pack.)
    I have a plug and play TRS HID Kit and for some reason my right light is intermittent. Sometimes it works some times it doesnt. I have been on the phone with TRS and they have sent me replacement parts with limited results. I am just a dumb grunt so I know nothing about electrical.
    Hope to meet up with more of you now that im stationed in AZ.
    Thanks,
    Sebastian
  2. Mar 27, 2013 at 9:32 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If I was going to be down that way I'd help you out... but alas... not planning to at this time.
    First things I"d look at though are ensure all connections are tight and secure. Did you do any splicing (most kits are plug and play so that shouldn't be an issue I'd think). If you did... did you solder the connections, and solder correctly? Check and verify reguardless.
    Also try switching the bulbs between lights and see if it follows, maybe it's just having issues striking for some reason. Also.... try switching ballasts and see if it follows, if it does then you have a faulty ballast.
  3. Mar 27, 2013 at 9:33 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
  4. Mar 27, 2013 at 2:22 PM
    dira1987
    dira1987 Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    When i was installing my PIAA lights they did the same thing. I took the ballast apart and found the connector inside the bulb was grounding itself against the back of the ballast. Maybe that is something that is happening with yours? Wish i could help but im in chandler and not good at lighting unfortunately. But thats what mine did and it was an easy fix!
  5. Apr 2, 2013 at 10:21 AM
    teamamerica
    teamamerica Get off your horse and drink your milk.
    Wy
    2009 tacoma
    none yet
    in huachuca?
  6. Apr 2, 2013 at 10:41 AM
    Aw9d
    Aw9d That one guy
    What parts were replaced? TRS support is really good so sounds like a bad connection somewhere.
  7. Apr 8, 2013 at 8:43 PM
    infantry
    sorry guys my computer never told me you guys responded!!!
    team america... yes here in this Sh$T hole.
    AW9D...Everything.. they sent me new ballasts and wiring... it worked for a couple weeks and now the same problem.. ive been meaning to call them back but at this point i have no idea what to say to them.
    I am headed back up to tuscon this weekend.. IF ANYONE could help me I will buy you a case of beer for sure.
  8. Apr 8, 2013 at 9:08 PM
    teamamerica
    Wy
    2009 tacoma
    none yet
    yeah, it's quiet though.
    but i live in huachuca city if you want to stop by this weekend and i'll look at if you want (i'm not a genius at it though)
    i'll pm you my number.
  9. Apr 9, 2013 at 9:02 PM
    infantry
    sweet thanks man. Ill be up in Tuscon all weekend so if not this weekend ill try and reach ya next weekend. Anyone else up in Tuscon?
  10. Apr 17, 2013 at 8:17 PM
    JeepAndrew
    JeepAndrew Nah bitch Jeep guy
    Andrew
    Tucson, AZ
    Offroad beast YJ/2015 Taco
    Lots-o-mods
    Just noticed this thread, I'm in Tucson and could help you if you haven't solved the problem yet.
  11. Apr 18, 2013 at 8:29 PM
    infantry
    sweet man thanks. I don think im heading up this weekend but probably next weekend. could you pm me your number?
  12. Apr 18, 2013 at 8:49 PM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
    PM'd
