Possible Mod Day - Suspension Install
Discussion in 'Hawaii' started by cubiclesurfer, Sep 3, 2014.
  1. Sep 3, 2014 at 1:57 AM
    cubiclesurfer
    cubiclesurfer [OP] Well-Known Member
    Kailua-Kona, HI
    howzit everybody! well, I have to be honest, I've been talking to a few different people about suspension questions after searching this forum for hours and hours. I ended up ordering up this suspension setup for my '14 DCSB 4x4:
    front - Bilstein 5100/OME 885x (with driver's side 1/4" spacer), all pre-assembled
    rear - Bilstein 5100/Icon AAL
    I'm keeping my stock UCA's for now, with the hopes that I can get away with it long enough to save up for some better UCA's.
    Soooo, I am an absolute dummy when it comes down to anything mechanical, but I've never really had the chance to learn either. A few people have been awesome enough to offer to help with the install, even after my confessions of possibly not being able to contribute all that much.
    Bottom line, Iven has offered his place up for a mod day to install my suspension. I'm still coordinating the date to get it done, and honestly, I have no idea how long this is gonna take, but I wanted to give everyone a heads up in case you're interested in helping out, or learning like I'll be doing.
    Mahalos Iven for opening up your garage! I'll update this post with the date/time when we figure it out.
    --- UPDATE ---
    so here's the day/time for all this to go down at Iven's house:
    9/14 (Sunday) at 8am
    thanks again, everyone
  2. Sep 3, 2014 at 11:08 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Pretty easy stuff right there.. Find a place and get the food...
    If the 5100s in the front will come fully assembled then that is almost as fast as changing out your rear shocks..
  3. Sep 3, 2014 at 1:20 PM
    808leo
    808leo Well-Known Member
    Kapolei, Oahu
    ‘21 super white dcsb 4wd
    5100 max setting, 285/70/17 ko2, FN 6 shooter, Subaru/kicker tweeters, JBL BassPro sub, nfabs, LED lights exterior/interior.
    LMK I'll come down and lift some beers :D
  4. Sep 3, 2014 at 3:35 PM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    Depends if u doing everything at da sametime or fronts den rear or visa versa. Should b anywea from 2-3 hrs.
  5. Sep 3, 2014 at 3:39 PM
    raycie
    Oahu, HI
    In need of $$$
    Throw the whole truck on stands, some attack the rear with the AAL and others take care of the front... No work needed after lunch and some beers..
  6. Sep 3, 2014 at 4:12 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Yep. I have enough tools and jack stands, we can do the front and rear at same time. Especially if Mike comes down. Even more tools. And don't let Leo wrench on it if the whole truck is on jack stands... Might fall off :p
  7. Sep 3, 2014 at 4:23 PM
    raycie
    Oahu, HI
    In need of $$$
    If you can get it, I would probably get some UCAs now.. We do have a GB going here with Marie at Boss4x4 till the end of Sept. Chime in on that thread or PM her to get some pricing.. If the guys are gonna be over and there are gonna be some extra hands, may as well get that done at the same time.
  8. Sep 3, 2014 at 5:04 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I think I've got swapping out the front assembly down to 20min per side on a 2wd. 4wd's take a little more time an finesse
  9. Sep 3, 2014 at 6:29 PM
    raycie
    Oahu, HI
    In need of $$$
    No need to do it the LCA method (especially if it is fully assembled), but could it also be done that way so the UCA would hold up the knuckle/spindle?
    But if the OP does pull a set of UCAs out of the bag, then never mind... just curious..
  10. Sep 3, 2014 at 7:37 PM
    cubiclesurfer
    Kailua-Kona, HI
    thanks for the input everyone. I won't be able to pull it together for UCA's right now, so the stock UCA's are gonna stay put. front's are fully assembled, so it looks like it should be a straight swap? I'll keep everyone posted on the day/time. shoots!
  11. Sep 5, 2014 at 12:12 AM
    cubiclesurfer
    Kailua-Kona, HI
    ok, updated the original post, but in case you don't want to scroll up, it's 9/14 (Sunday), 8am, at Iven's house!
  12. Sep 5, 2014 at 12:24 AM
    bullaculla
    Da big big island!
    Sounds good. Bring breakfast and beer :D
    Do you have new U bolts? Thankfully your truck is still new so no need to deal with rusty frozen bolts.
  13. Sep 5, 2014 at 1:46 PM
    cubiclesurfer
    Kailua-Kona, HI
    hmm, does the Icon AAL kit come with new U bolts? I'll open up the box and double check, if no more, I'll try get some new hardware this weekend. I think I've read that you shouldn't reuse U bolts... is that true for my case? truck is only 2 months old, with 1,500 miles :D
  14. Sep 5, 2014 at 1:52 PM
    raycie
    Oahu, HI
    In need of $$$
    If you need some.. I got a set of OME u-bolts that I didn't use cause I did a flip-kit.. $20...
    And as for a 8:00 start on a Sunday... That means leaving Kapolei about 7.. I'll probably get down there about 9:00.. At least the truck should be on stands and all tires off at that point.. lol..
  15. Sep 5, 2014 at 2:12 PM
    bullaculla
    Da big big island!
    You can reuse the stockers. They are still new and weren't properly torqued anyway.
  16. Sep 5, 2014 at 2:31 PM
    cubiclesurfer
    Kailua-Kona, HI
    I think Iven is in Hawaii Kai, right? that's pretty much the other side of the world from us. I might have to pack a cooler and snacks for my drive there. haha
    sounds good!
  17. Sep 6, 2014 at 2:09 AM
    cubiclesurfer
    Kailua-Kona, HI
    I don't know if it matters, but the Icon AAL's did come with a set of new U bolts and hardware. I'll bring them just in case.
  18. Sep 10, 2014 at 6:52 PM
    raycie
    Oahu, HI
    In need of $$$
    I'm getting sick.. hope to kick it, but either way you are in more than capable hands with Iven.
  19. Sep 15, 2014 at 2:35 AM
    cubiclesurfer
    Kailua-Kona, HI
    thanks to Iven and Mike for installing the suspension this morning. the whole process probably took about 3 hours, and everything came out cherry.
    learned a lot and got to watch Iven and Nate's RC races. never knew an RC could go 43 mph :eek: good meeting everyone today and I hope to make it to a meet soon. I'll try getting a picture up in the next couple days.
  20. Sep 15, 2014 at 7:19 AM
    bullaculla
    Da big big island!
    Cool man. How's the ride?
