Possible Radio Swap Out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TSmalls89, Aug 14, 2013.
  1. Aug 14, 2013 at 6:44 AM
    TSmalls89
    TSmalls89 [OP] Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
    SO I have been contemplating removing the stock radio and swapping it out with an aftermarket. My main concern is losing the bluetooth features and front aux/audio jack that come stock on the 2013s. Has anyone with a 2013 done this and still been able to use these options??
    If I lose these, wouldn't really be worth the new radio.
  2. Aug 14, 2013 at 7:44 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    From what I have read so far you should be able to retain the stock buttons on the steering wheel, even with an aftermarket stereo.
  3. Aug 14, 2013 at 7:53 AM
    81shark
    81shark Well-Known Member
    aux jacks are junk....unless you don't mind lower quality tunes.
    i recommend going aftermarket with aftermarket speakers and a sub....add in an ipod and rip music at a lossless level.
  4. Aug 15, 2013 at 3:58 PM
    Riverdog
    Riverdog Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
    There are many aftermarket decks that have bluetooth capabilities and front aux jacks. There are also adapters for many aftermarket decks that allow retain the use of the buttons on the steering wheel. With an aftermarket deck, you'll also likely get much better sound quality.
  5. Aug 15, 2013 at 4:10 PM
    jparf
    jparf blissfully biased
    Mechanicsburg, PA
    15 Silver Highlander Limited
    Search. A lot of people have done it including me. You'll need to invest in some parts and do a lot of research but it can be done. GL!
  6. Aug 15, 2013 at 4:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  7. Aug 15, 2013 at 9:33 PM
    larrybbaker
    larrybbaker Well-Known Member
    larry
    South Central PA
    2013 MGM DCLB TRD SPORT 4WD
    OME 885 | Bilstein 5100 x 4 | WeatherTech Window Visors | VAIS Tech SiriusXM Adapter |Alpine KTP-445U Amp | Anytime fog light mod
    I had put aftermarket HU in my last several vehicles but with the Tacoma I stayed stock to retain all built in features BUT I added an Alpine KTP-445U amp and the VAIS Tech satellite adapter. At some point will upgrade the speakers but for now I have greatly improved sound quality and volume and Satellite radio.
  8. Aug 15, 2013 at 9:39 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
