Possible rear end noise.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Levisbustedtacoma, Dec 20, 2022.
  1. Dec 20, 2022 at 4:20 PM
    Levisbustedtacoma
    Levisbustedtacoma [OP] Well-Known Member
    Levi
    01 4x4 extracab
    Bilstien 5100s eibach coils Dakar leafs Chinese balljoints
    So I've got a noise at all speeds that matches the speed of the truck. Almost sounds like another engine lol. Trucks at close to 300k. I've gotten toyo open country at3s the 10bply and had them mounted and balanced to the wheels then took them home and put on the truck. It sounds like it's coming from the back. Any ideas? My hope is it's the tires
  2. Dec 20, 2022 at 4:22 PM
    eon_blue
    Azusa, CA
    If you just put the tires on and the noise started then its the tires. I'm not familiar with those Toyos but I do know that more aggressive AT and especially MTs will make a lot of road noise. What PSI are you running them at
  3. Dec 20, 2022 at 4:33 PM
    Levisbustedtacoma
    Levi
    01 4x4 extracab
    At 35 psi. It's hard to say when the noise started. What's weird is if my windows are down it's almost un noticeable. Now that's its cold out and my windows are up I can really hear it. It's not on acceleration or deceleration it matches the speed of the truck. This is why I think tires. The last 2 sets of tires were VERY loud mud terrains.
  4. Dec 20, 2022 at 7:40 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    What does noise sound like? If it was tire hum it’s should happen all the time and get louder with greater speed. Check your out your drive shaft and differential.
  5. Dec 20, 2022 at 9:21 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Why is it hard to pin down when the noise started? It either started before you changed the tires, or after you did. 35 PSI is high for a 1st gen Tacoma.
    That being said, you need to start inspecting your drive line to rule that out. Put the rear end up on some jack stands, and rotate the wheels. You're listening for bad bearings or u joints- wheel, diff, etc...
    69 Jim likes this.
  6. Dec 21, 2022 at 6:11 AM
    Cucvfan
    Cucvfan Well-Known Member
    assuming you truck has a spare tire. Round up 1 more spare and swap out your rear tires to see if that changes anything.
  7. Dec 21, 2022 at 8:42 AM
    Levisbustedtacoma
    Levi
    01 4x4 extracab
    I'll try flipping them around. No spare
  8. Dec 21, 2022 at 8:59 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Just to try to save you some time- I don't think rotating the current tires will make a difference if the tires are making the noise. The point of using a spare (or rather two spares) is to change the whole tire itself. Edit: And just to put this out there- don't swap just one spare on if the tires are different sizes, you'll grenade your diff.
    You still haven't clarified if the sound is new since the tires or preexisting. If it's at all preexisting, the tires are a complete red herring, and you need to be inspecting other components in the drive line for wear.
