Possible Tacoma project?
Discussion in '1st Gen. Builds (1995-2004)' started by cdyblnd, Jan 31, 2012.
  1. Jan 31, 2012 at 6:24 PM
    cdyblnd
    cdyblnd [OP] Member
    Cody
    West Virginia
    01 Tacoma SR5
    Tow hitch, K & N intake, Firestone Destination A/T, Xentec 8000k hid kit, Magnaflow cats, Gibson Cat back, TRD wheels, Bilstein suspension upgrade
    Hey everyone, I've got a stock 2001 Tacoma 2.7L 5 speed. I'd really like to make some modifications but I can't quite decide where I want to start with it. Can anyone with a little more experience shoot me some ideas of a good place to begin?
  2. Jan 31, 2012 at 6:25 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    check out the suspension sections, and the easy mods.
    aesthetics (decals, blacking out emblems, new lights) are always a good place to start. that gives you time to do some research into suspension mods as well
  3. Feb 1, 2012 at 10:17 AM
    cdyblnd
    cdyblnd [OP] Member
    Cody
    West Virginia
    01 Tacoma SR5
    Suspension was kind of one of my ideas. I wanna get it up enough to clear 33s. What brand of lift would you reccomend?
  4. Feb 1, 2012 at 12:25 PM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    Not so much brand... Alot of brands are good. Depends on your preference.
    You pay for quality you're going to get quality. What you need to stay away from are body lifts and spacer lifts. You're better off saving for an actual suspension lift. Check out ToyTecLifts.com Also, does your truck have 5 lugs on the wheels or 6?
    Welcome to the forums!
    :cheers:
  5. Feb 1, 2012 at 1:14 PM
    cdyblnd
    cdyblnd [OP] Member
    Cody
    West Virginia
    01 Tacoma SR5
    It's got a 6 lug. I know what I wanna do about wheels and tires, and I pretty much had my mind set on a suspension lift. I just don't know which brand I should try to get or if there was anything I should stay away from.
  6. Feb 1, 2012 at 1:15 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    like asid above stay away from body lifts and spacers.
    in order to fit 33s on a 3 inch lift you will need to trim the wheel well so you dont rub. are you comfortable with that?
  7. Feb 1, 2012 at 1:20 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    as far as lifts ,you gotta decide what your budget is-
    good suspension lifts range anywhere from a $400 to 5000, whats your budget OP?
  8. Feb 1, 2012 at 1:24 PM
    cdyblnd
    cdyblnd [OP] Member
    Cody
    West Virginia
    01 Tacoma SR5
    I kinda figured between a lift, wheels, and tires I'd be spending around $3,000.
  9. Feb 1, 2012 at 1:27 PM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    That's a pretty good budget!
  10. Feb 1, 2012 at 1:28 PM
    97yota4wd
    Eric
    Mesa, AZ
    thats a pretty good budget.
    wheels and tires.... 1300
    bilstein 5100s and eibach coils 250 (i think)
    add a leaf 80
    thats like the cheapest for a true 3 inch lift. or you can get a little more expensive by adding upper control arms and rear bilstein shocks for a little less than a grand i believe. or you get get into more expensive shocks too
  11. Feb 1, 2012 at 1:29 PM
    cdyblnd
    cdyblnd [OP] Member
    Cody
    West Virginia
    01 Tacoma SR5
    My dad sells tires and wheels so I can get them at cost, I just wanted to get the suspension done right and then start thinking about a few other things with my truck.
  12. Feb 1, 2012 at 1:39 PM
    97yota4wd
    Eric
    Mesa, AZ
    well what are you planning on doing with your truck? theres different setups for different things, like crawling, hauling ass, or a mixture of both.
  13. Feb 1, 2012 at 1:40 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    will you wheel the truck?
  14. Feb 1, 2012 at 1:43 PM
    cdyblnd
    cdyblnd [OP] Member
    Cody
    West Virginia
    01 Tacoma SR5
    It'll probably see some mud and trails, the truck doesn't haul ass as it is being stock on 31s.
  15. Feb 1, 2012 at 1:45 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    take a look at a OME 3" set from wheelers or toytec's ultimate lift kit (both are sold as complete lift kits, saves you the headache of parting the lift if you have the $$)
  16. Feb 1, 2012 at 1:46 PM
    97yota4wd
    Eric
    Mesa, AZ
    okay but what do you want the truck to be capable of doing?
  17. Feb 1, 2012 at 1:50 PM
    97yota4wd
    Eric
    Mesa, AZ
    going to 33s in a 4 banger will kill all your power and you will be in close to single digit mpgs. you think about re gearing?
  18. Feb 1, 2012 at 1:55 PM
    cdyblnd
    cdyblnd [OP] Member
    Cody
    West Virginia
    01 Tacoma SR5
    I kinda figured it would, that's why I wanna plan all of this out before I start buying parts. I've even thought about just doing a small lift to clear a set of 265/75/16 mud tires just to get a more aggressive look. I'm not gonna start shelling out on money on a bad idea.
  19. Feb 1, 2012 at 1:57 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Why is this in the build section?
  20. Feb 1, 2012 at 1:59 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    you can fit those stock
    if you have money, you can grab adjustable coilovers and have them set at anywhere from 0-3" of lift. if you dont crank em all the way up you'll have a lift with a much better ride than stock
